Discussion about BFX-Delay
geposted Wed 16 Sep 20 @ 9:17 pm
@staff problem, in app DL results in x64 not compat dialog
geposted Wed 16 Sep 20 @ 10:06 pm
Seems to be fixed, ok here
geposted Wed 16 Sep 20 @ 11:03 pm
@nico even x64?, I tried both beta & public, same result> not compat, let me try x86
*edit* x86 initialises but in brutal, unthinking, press every button quickly testing I was picking up CBR interference [lots of static] maybe it's a set and start fx, I'm being brutal just because I'd want the same for my releases.
geposted Wed 16 Sep 20 @ 11:26 pm
well didn't try it a lot. I installed x86 to take a look too
both x86 & ia64 DL install OK
IT IS A DEBUG VERSION
As i'm on my dev PC it loads debug dll OK ^^
maybe you missed latest Visual C runtime in debug mode ?
geposted Thu 17 Sep 20 @ 12:02 am
I'm going to pull this one again, no effect_beats control?
I admit I am being critical but no more than I'd wish on myself
geposted Thu 17 Sep 20 @ 12:09 am
![](/img/321184/22308/Capture 9-17-20.png)
system type: 64 bit
geposted Thu 17 Sep 20 @ 12:03 pm
Yes, debug mode DLL :(
working fine in development system only (latest development runtime libraries installed)
https://imgur.com/a/wRDDKTi
(perso experimental skin in used too)
geposted Thu 17 Sep 20 @ 12:28 pm
@Deun-Deun : Always a good idea to set code generation in Visual Studio to Multi-Threaded for release builds and Multi-Threaded Debug for debug builds instead of the DLL variants.
Also for sharing a plugin it is of course better to make a release compile and upload that instead of the debug build.
geposted Thu 17 Sep 20 @ 12:35 pm
live now, seems to be fixed, I can't see how it differs to native delay, but being external thus re-namable [for multiple copies] that's a good thing.
still think dial 2 for length is better than buttons, effect_beats is also an idea.
geposted Sat 10 Oct 20 @ 10:57 pm
i have te same problem some effects the ones with DMX or or the other x -es in frton are all uncompatiblo on my windows 10 system. can you tell me how to solve this issue?
thank you
Jan
thank you
Jan
geposted Fri 06 Aug 21 @ 11:53 am
