| Autor | - Topic: BROADCASTING LIVE AND RECORDING THE SET - |
Winamp has a pluggin that records the streaming broadcast. I used to record using it when I was broadcasting to a shoutcast server. |
So what do i do in winamp? Thanks for responding.. Can i record 320kbps? |
ANY wave editor will record your sound from windows. Even the built in windows sound recorder can record your set, while broadcasting.. If you want a more advanced editor than Windows own sound recorder, use Audacity. Free wave editor http://audacity.sourceforge.net/ |
Audacity should be able to record master sound, and by that record hercules. |
Try streamripper for winamp (free) It does a damn good job at recording a shoutcast stream from within winamp (you play the stream in winamp and then hit the 'start' button. It does a nice job of splitting the stream into individual MP3 tracks. google streamripper and I'm sure you'll find it! |
Thanxxxxxxxxxxxxxxxxxxxxx |
loura wrote : Thanxxxxxxxxxxxxxxxxxxxxx Loura...this web site does not track the number of times a user posts to increase their standing in the community. Please stop spamming the forum saying Thankxxxxx. It will get you no where, and possibly end up with your account getting locked. |
Personaly I use a splitter and feed one to the speakers and the other goes into a desktop that records the audio with Audacity |
am trying to broadcast live mixin session using virtual dj but people are unable to open up the link..any ideas? |
Honestly, you can record a live set while broadcasting live. If your djing on a computer running vdj with your tcv's or tccd's and you feed a aux out into the a line in on a second computer, on that second computer that's where you would record from. or vice versa. that should do the trick. POW! |
So what does one need in order to broadcast live? My setup consists of two cdj-400's djm-400 and my lappy.... |
A stable internet connection. ;-) But do you think, you are in the right Topic? Haui |
I thought I was in the right topic. The header does read broadcasting live AND recording the set. My next questions would be on recording ;). |
My apologizes if I am not in the right topic.... |
The Topic called BROADCASTING LIVE AND RECORDING THE SET ;-) But anyhow, go on ;-) Tell us all your questions. |
I use wavelab on a second pc ;-)BEST!!! ![]() |
thx 4 da help playa |
