| Autor |
- Topic: Problems installing slideloop fx [not compatible with VDJ-Cue 4.x & 5.x] - |
Posted Mon 12 Jan 09 @ 8:15 am
when i click on it to install it tells me i don't have virtual dj installed. i run Numark cue is this the reason? |
Posted Thu 15 Jan 09 @ 3:58 am
Same here please help. |
Posted Thu 15 Jan 09 @ 6:27 am
It does predate Numark Cue, so the installer probably doesn't recognise it.
You could install the trial of VDJ, then copy the plugin over? |
Posted Fri 16 Jan 09 @ 7:17 am
thats kinda what i figured. oh well no sideloop then. |
Posted Fri 16 Jan 09 @ 7:47 am
I know why slideloop doesn't work.
This is a very old effect and when they made it, VDJ was different; some years ago, all the effects were installed in Effect folder while today in Plugins\SoundEffect.
So go in VirtualDJ/CUE folder and open the EFFECTS folder: inside it you will find sliderloop.dll, cut and paste sliderloop.dll in Plugins\SoundEffect folder, start CUE and enjoy your new effect!!!!;-)
Posted Fri 16 Jan 09 @ 8:56 am
djsynystr wrote : thats kinda what i figured. oh well no sideloop then. If you install the VDJ trial, it should detect it and install. You can then copy the plugin across as per the previous members post :) |
Posted Fri 16 Jan 09 @ 9:04 am
what about the modify the old .exe to allow CUE users to install each plugin as well? |
Posted Fri 16 Jan 09 @ 9:05 am
It will be fixed soon, only moderators and teamers can ;) |
Posted Fri 16 Jan 09 @ 9:15 am
I'll just go sit in the corner then :p |
Posted Fri 16 Jan 09 @ 11:15 am
Cioce, if you fix this the destination folder and this issue for CUE users for all old .exe files, I am sure most users will say thank you;-) |
Posted Sat 17 Jan 09 @ 7:32 am
I was going to fix it, but first I tried the effect in VDJ.
And it doesn't work correctly. As this is an old effect for VDJ 2.xx and 3.xx, I didn't fix the installer, and I added a note on the download page to say it isn't compatible with 4.xx and above. |
Posted Sat 17 Jan 09 @ 7:48 pm
Ok. Thank you so much JeremK. |
pOpYDJ  Professional edition user   |
Posted Sun 25 Oct 09 @ 12:36 pm
Could anybody please make this one compatible with VDJ6.
Thanks cu pOpY |
