Forum: Hardware Technical Support - Topic: Windows 7 and MK2
Questions or comments about the supported hardware by VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
For general troubleshooting and MIDI controller configuration, please see Config & Troubleshooting.
Hardware products
VirtualDJ Forum
Hardware Technical...
Windows 7 and MK2
Autor - Topic: Windows 7 and MK2 -
Djmadman73
Professional edition user
Posted Thu 14 May 09 @ 9:50 am
Just a little FYI I have been playing with the RC of windows 7 and tried to install the MKII with the new 2009 drivers and kept getting the error "The drivers of your sound card are older than the one on this computer. Please reinstall the HDJC package again." Which I am assuming the firmware is older? might have to flash the MKII with new firmware but then again you never know?
Like I said this is just FYI and this box I have it on is for testing purposes and I know VDJ and Herc has no support yet...
cioce
Ultra-VIP Member
Posted Thu 14 May 09 @ 10:01 am
http://www.herculesdjmixroom.com/it/forum/en-software/002770/
DJ drivers supporting Windows 7 will be released by Hercules when the operating system will be offically released by Microsoft.
Djmadman73
Posted Thu 14 May 09 @ 10:29 am
Thanks for the info!! Like I said I was just posting my findings thats all not trying to cause any problems. Just wanted to give people who wanted to try windows 7 a heads up on what I am doing.
admaust
Limited edition user
Posted Sat 07 Nov 09 @ 6:48 am
My mk2 isn't working on Windows 7 (32bit) with the latest driver (2009_HDJS_3.exe). I get this message: "The Hercules DJ Series driver found on your system is older than expected. Please reinstall the Hercules driver package." I've done so numerous but without any success of getting the mk2 working. When plugged in, all lights remain on. I've also tried installing the drivers in compability mode with all versions of Vista, but again without luck.
djspc
No license user
Posted Wed 07 Apr 10 @ 10:31 am
has anybody solved the problem thanks
DJ Phatso
Experienced pro user
Posted Wed 07 Apr 10 @ 3:00 pm
The current web package (4.HDJS.2009) is fully compatible with Windows 7
acw_dj
Atomix Productions
Posted Mon 12 Apr 10 @ 12:56 pm
Current Hercules DJControl drivers support Windows Xp, Vista and 7 in 32 and 64 bits. SO the answer is YES, MK2 is supported in Windows 7 and MAc OS X as well.
http://ts.hercules.com/es/index.php?pg=view_files&gid=2&fid=28&pid=177&cid=1
PC: ftp://ftp.hercules.com/pub/webupdate/DJCSeries/2009_HDJS_4.exe
MAC: http://ts.hercules.com/download/pub/webupdate/DJCSeries/DJSeriesInstall_1_77.pkg.zip
chazzbo
Posted Wed 28 Apr 10 @ 12:39 pm
I installed the new drivers on windows 7 (64bit). initially didn't work then I read somewhere not to connect device when instructed but do it afterwards. Did this and in installed the firmware updates etc. Thought it would work then - no red cross in through the DJ emblem in task bar. However it is still not working for audio as if device is not connected, will not play test tone etc. Any ideas.
It seems as though it's being recognised when pluged in, red cross goes away, I can open hercules control panel. All lights come on then just 2 green audio source lights come on.
DJ Phatso
Posted Wed 28 Apr 10 @ 12:51 pm
@ chazzbo
Please refer to your other post
DjSimo95
Posted Fri 17 Dec 10 @ 12:13 pm
Ciao A Tutti Vorrei Mi Chiamo Simone E Vorrei Sapere Se è Possibile Trovare Dei Nuovi Drivers Per La Mia Hercules Mk2 Poichè Come Sistema Operativo Ho Windows 7. Mi Potreste Dare Dei Link Dove Eventualmente Scaricarli? Grazie In Anticipo.
DJ Phatso
Posted Fri 17 Dec 10 @ 3:18 pm
