I need HELP!
My laptop crashed, and reformatted... had installed program for my Hercules DJ Console RMX and used Virtual DJ Pro 7. Thought everything went smooth until I realized that all Effects buttons (1-6) weren't the same as it used to be with VDJ Pro 6.0.5. Anyone help me on how to re-assign functions and effects to buttons? I'm not so familiar with everything as it came as a present... I really love playing music with these, but based on the manual itself, instructions aren't enough (basically for Virtual DJ 5 DJC Edition) plus I don't have the old installers. Please, can somebody help me?
geposted Tue 26 Jul 11 @ 10:22 am
Driver for Hercules DJ series (v2.87) supporting OS X Lion have been released!
Mac OS X driver package for DJ Console Series - Version 2.87
2011-07-19
System Requirements:
- MAC OS X 10.7x (Lion)/10.6.x (Snow Leopard) /10.5.x.(Leopard)/ 10.4.11 (Tiger)
- Intel Core Duo 1.66 Ghz and higher, G4/G5 1.5 Ghz
Supported products:
- DJ 4Set
- DJ Console 4-Mx
- DJ Console Mk4
- DJ Control MP3 e2
- DeeJay Trim 4&6
- DJ Control Steel
- DJ Console Rmx
- DJ Console Mk2
- DJ Control MP3
Installation procedure:
1- Click the link below to download the new driver for your Hercules DJ product.
2- Once the download is complete, double-click the installation file and follow these instructions to install the new driver.
NOTE: At the end of the installation, you may be prompted to update your firmware version if you have not already updated it. Please be sure to strictly follow the on-screen instructions for this very important procedure.
Changes :
- Added support for OS X 10.7 Lion
Download -> http://ts.hercules.com/download/pub/webupdate/DJCSeries/DJSeriesInstall_2_87.pkg.zip
2011-07-19
Supported products:
- DJ 4Set
- DJ Console 4-Mx
- DJ Console Mk4
- DJ Control MP3 e2
- DeeJay Trim 4&6
- DJ Control Steel
- DJ Console Rmx
- DJ Console Mk2
- DJ Control MP3
Changes :
geposted Wed 27 Jul 11 @ 1:32 am
Hello, I'm using Hercules DJ Console MP3 with the VirtualDJ version 3.1 that came with it, when I bought it. Everything was working, until I decided to use it on another computer. It still works but somehow when I press the Sync button to synchronize the next track, it just starts playing. How can I disable this?
I've already updated to the latest Hercules drivers and I'm using Windows XP. I've searched about it in the forum a little bit, but I don't have that time.
Thanks in advance!
Thanks in advance!
geposted Sun 31 Jul 11 @ 11:16 am
Problem solved!
geposted Sun 31 Jul 11 @ 1:05 pm
Hi everyone in the forum
Ok I have major questions regarding the Hercules RMX and 7.4 VDJ set up.
I use the RMX in VDJ as usual - I monitor using the Hercules inbuilt soundcard and put the setting to USB and mic. I recently decided to start mic work in broadcasting streaming through shoutcast servers. I bought myself a blue encore 200 mic, a MR100 Berhinger preamp for phantom power and boost. However when I have done some practising with no streaming, just normal testing via the hercules own soundcard monitoring, I press that mic on /off button and I hear no voice in my headphones, no volume drop or anything via the RMX soundcard monitoring soundcard to suggest that anything is working.
Am I correct in assuming that the RMX will not broadcast its mic input over VDJ itself nor over its own soundcard intermals itself but will broadcast when streaming?? And if this is not the case what on earth am I doing wrong? I dont even hear anything via the line 1 input either yest when I used to stream with my trusty numark Total control and my condense mic hooked up to a usb preamp, I could monitor through VDJ fine and mute the mic via the tedious windows line in mute option.
So is this a mistake on my part, or does the mic option not broadcast through the RMX for monitoring use?
Thanks
Thanks
geposted Fri 12 Aug 11 @ 12:36 pm
hiua, the mic on your hercules is only a mic throughput. there is no return feed to your computer. therefore it is not possible to use it for broadcasting.
to use a mic for broadcasting you need to have it connected to
A: usb soundcard
B: mic in on your computer
c: line in on your computer
hope this helps.
oh and you will need to setup via your advanced config for the mic to work in conjunction with your hercules also being used.
A: usb soundcard
hope this helps.
geposted Tue 16 Aug 11 @ 6:17 pm
I just recieved my Hercules Control MP3 e2 in the mail and i am already a registered Virtual DJ user, my question is do I have to instal the version of virtual dj that came with my controller or can i use it with my current version?
geposted Tue 13 Sep 11 @ 5:47 pm
Your profile info to the left suggests that your existing version is another console version as it says you are a 'Limited User'. In which case you will need to install the console version for this controller too.
Only registered pro users get full access to all mappers for all supported devices.
Cheers,
Roy
Cheers,
Roy
geposted Wed 14 Sep 11 @ 2:08 am
You currently have VirtualDJ Broadcaster, which does not support MIDI controllers (It is for mouse and keyboard use only, although MIDI controllers can be tried for 10 minutes at a time as a trial of the full VirtualDJ Professional.)
You will need to install VirtualDJ LE that came with your controller to use it without any time limit. Or you can upgrade to the full VirtualDJ Professional at a discount: http://www.virtualdj.com/buy/index.html (The VirtualDJ LE serial number will probably give you the most discount.)
Please see http://www.virtualdj.com/products/comparison.html for a list of the main differences between each version.
geposted Wed 14 Sep 11 @ 6:39 am
2011-09-12
NEW Hercules DJ Console Series Driver - 2011_HDJS_4 package
Changes:
- Reduced ASIO latency.
Download:
http://ts.hercules.com/download/pub/webupdate/DJCSeries/2011_HDJS_4.exe
Changes:
Download:
geposted Wed 21 Sep 11 @ 8:33 am
Having issues with the new drivers. Working with vinyl timecode, it is playing in reverse now. worked fine before the upgrade. any suggestions?
Thanks!
Thanks!
geposted Tue 27 Sep 11 @ 5:25 pm
Hi all,
Does anyone having a problem setting up a MAYA44 with vdj 7 using window 7? I am having a hell of a time getting that thing to work with the RMX that i like to continue using as a mixer for videos and do away with its jogwheels and player capabilities.
if no one is using the maya, can anyone tell the best soundcard to use for time code. I saw some tutorial videos on Youtube but don't seem to help me.
what can i tell you to help me?
Omar
Omar
geposted Thu 20 Oct 11 @ 1:40 pm
I am trying to map the rmx crossfader and not having much success.
Example: deck a is playing a song. I now want to use the crossfader to
fade out deck & and start deck b, and vice versa.
Here is the last one I have tried:
crossfader & param_greater 0% : parm_smaller 100% : deck a play & deck b play : deck a stop : and deck b stop
Any suggestions please?
geposted Thu 20 Oct 11 @ 2:28 pm
The syntax in the above line is incorrect:
crossfader & param_greater 0% ? param_smaller 100% ? deck left play & deck right play : deck left stop : deck right stop
Please see:
http://www.virtualdj.com/wiki/Fader%20start%20using%20the%20crossfader.html
http://www.virtualdj.com/wiki/Referencing%20a%20specific%20deck.html
http://www.virtualdj.com/wiki/VDJScript%20Examples.html
http://www.virtualdj.com/wiki/VDJscript.html
Please see:
geposted Fri 21 Oct 11 @ 7:07 am
your RCA's are plugged in backwards most likely...
geposted Fri 21 Oct 11 @ 11:35 am
Thanks!
Thanks!
most likely your RCA's are plugged in wrong. swap the left and right on one end and you should be good.
geposted Fri 21 Oct 11 @ 11:37 am
jolofboy wrote :
Hi all,
Omar
Omar
What are you trying to do with the Maya? also make sure you are using 64 bit drivers if you are running a 64bit OS. Also what are you using for timecodes(cdj's, vinyl, etc.)? The Maya does not support phono, to Technics 1200's are a no go...
geposted Fri 21 Oct 11 @ 11:40 am
Team:
Is the one you posted the correct one that will work?
Obviously I am not too adept at scripting.
Thank you
Thank you
geposted Fri 21 Oct 11 @ 11:43 am
I'm using my mac with virtual dj pro 7 that's connected to a numark external mixer. I am mixing with my laptop; no turntables. I fade left to right for sound on the mixer. The problem I am having is the left channel is lower in volume than the right. I have checked all of my connections; any suggestions? NEED HELP!
geposted Mon 24 Oct 11 @ 11:03 pm
I NEED HELP! PLEASE ANSWER :D
Right, so i'm very new to DJ'ing and i thought about getting the MP3 E2, but i also want to get this along with the korg micro key and the korg nanopad, so the problem is i want a program where i can use the nanopad and the MP3 E2 together, or at least be able to sample with the nanopad, ANY HELP? Thanks :D
I also wondered if i can use iTunes with the VDJ that ships with the MP3 E2, and if not how to use my music.
(I am using a macbook pro, the newest snow leopard, if that helps with software)
Please Help, Thanks,
Kevin :D
Kevin :D
geposted Tue 25 Oct 11 @ 7:27 am
