Topic: protection error 2 and protection error %i . NEED help . I have a party on 30-july. I cannot install vdj-6
I get this error . Need help.
geposted Sun 26 Jul 09 @ 2:50 pm
sischoPRO InfinityMember since 2005
Have you got NOD32 as antivirus?
geposted Sun 26 Jul 09 @ 4:10 pm
yes and i quit nod32 before installation.
geposted Sun 26 Jul 09 @ 4:23 pm
geposted Sun 26 Jul 09 @ 4:26 pm
Uninstall everything then using Reg tool in download section delete reg entries (cant remember exact wording).
Reinstall with nod 32 turned off, then turn on nod, start VirtualDJ allowing it internet access it will confirm valid installation over the net.....
should then be alright.
Normal install does not require internet verification, but if there has been a protection error it puts up a red flag that needs to be cleared over the internet.
geposted Sun 26 Jul 09 @ 9:07 pm
PROBLEM SOLVED . Thank you very much.
I had to uninstall completeley nod32, not just turn off.
geposted Mon 27 Jul 09 @ 7:53 am
Getting a "PROTECTION ERROR 2" now that I have attempted to install the latest updates. I am running McAfee OAS if that has anyting to do with it.
HELP !!!
geposted Sun 19 Jun 11 @ 7:29 pm
geposted Mon 20 Jun 11 @ 6:26 am
