Forum: Old versions
Topic: system requirements for virtual 6
What are the system requirements for virtual 6?
geposted Fri 21 Aug 09 @ 6:49 am
Directly from the VDJ Products page....
The minimum requirement to run Virtual DJ is:
* PIII 850 MhZ computer
* 1024x768 SVGA video
* DirectX compatible soundcard
* 512 MB RAM
* 20 MB free on the hard-drive
The recommended configuration is:
* PIV 3 GhZ computer
* 4.1 DirectX compatible soundcard (with front and rear separate outputs)
* 1024 MB RAM
* 200 MB free on the hard-drive
The recommended configuration to mix video is:
* Dual Core 2 GhZ CPU
* ATI or nVidia video card w/256Mb of Dedicated DDR3 memory (dual output capable)
* 2048 MB RAM
geposted Fri 21 Aug 09 @ 7:33 am
thanks
geposted Fri 21 Aug 09 @ 2:27 pm
