| Autor | - Topic: How do I record my own voice effects on virtual dj? - |
Im a dj and im unsure about this procedure. If I want to shout out "WOW" on my dynamic mike, and record it as a fancy sound effect how would I do so? |
I'd also like to know if it is possible. Thanks |
I do my sound effects and DJ drops through my Pioneer DJM-800 mixer which has effects that allow me to make some cool drops. I record them with either my Yamaha Pocketrac 2G or I do them through Serato with my SL3's record feature. I don't use VDJ to record because it can't send and return so I can record my mixer's effects through VDJ. It's best to do your drops with an external recorder. DJ RuDe |
How Do i Creat My own DJ name Effects How do I make my own DJ Name Jingle,effect or sampls in an audio format,I tried making my own DJ jingle name....exampl........ Dee J spinash .. Dj spinash, But i don't know what to do.If there is any software of anythng that can help me creat ma own,i wanted to know how i can create ma own name Jingle ,so that i can play it when ever i am on a show,i am Just 19 years and i want to be a great Dj can any one help ....can any one help me ..this is ma email address plss help me spinash4u@yahoo.ca |
For jingles (and remixing as well) I think ACID is an easy and useful program. You can download a free version and try: http://www.acidplanet.com/downloads/xpress/ Best with this is the "nondestructive editing". You can drag the sounds/loops around until you're satisfied, then just "render to new track". For looped jingles there is BPM and good timestretch functions. If you want to change something, just open the project, edit and render again. No cutting directly in the soundfiles makes it possible to edit without any quality loss. Just a suggestion... (and you can record directly into the program, for example your voice) |
Thanks dj_ciceron Will that Sofware be all that help full??? And how do i creat an artificial Jingle out of that like the TEXT and SAY software. Willl luve to collect more skills form the Senior Djs Around this Hall, Just 19 years . Artificial Radio Or Dj name Jingle maker ! ! ! |
Maybe a little missunderstanding. I've never heard of artificial jingles "on the fly". For me a jingle is a trademark, like a logo. So I want it to always sound the same, and be perfect mixed/produced. Because of that I produce all jingles at home, and at a gig I just play them. Only "artificial" I tried is AnalogX Sayit http://www.analogx.com/contents/download/Audio/sayit/Freeware.htm Technical you could with that render a wav-file, load it into VDJ and play it out. |
U CAN MAKE A FILE ON A PROGRAM SUCH AS MIXCRAFT OR AUDACITY OR VARIOUS PROGRAMS AND SAVE YOUR VOICE FILE AND SIMPLY UPLOAD IT ONTO UR VIRTUAL DJ SAMPLES |
dj_ciceron Thank you Very Very Very Much This was what i was looking for exactly.... Thanks once again... Thank you again and again. Send me ur Email Address Ofline to cvv_deamon on yahoo so that i can email you and communicate with you frequently and privatly. Thanks once again |
Can Someone Help me im trying to record a mix on virtual dj with my DMC2 but evrything that i do it records it..like when i cue the song,,or when i listen a part of the song on my headphones... HOW CAN I RECORD A MIX WITHOUT GETTING ALL THIS???????? |
how do u get the text code.. |
How can i record my voice in virtual dj ?? Whats a easy way to earase the voice in a song usin virtual dj ?? |
