| Autor | - Topic: help me plz for vdj 6.0,2 can connect well with my denon 3700 in midi - |
Did you follow the guidelines in this post -- http://www.virtualdj.com/forums/115215/x/ -- read the first 2 posts. |
i cant put my denon 3700 in midi with vdj 6.0.2...not working ...help me plz problem on mac os x leopart |
Then you have not followed all the information that is in that post ... and if you have then please be more specific in what is or is not happening. What you have posted tells us nothing .... |
sorry ...my english is not good lol i want to connect my 2 denon 3700 cdj with vdj 6.0.2 in midi but not working !!! |
After i installed the latest firmware update from Dennon i had no trouble at all with my S3700... After installing the firmware you should be able to set up the decks very easily... Use the eject button to set the left and right decks, and when starting VDJ, make sure your s3700's are already in midi mode... Hope that helps. |
New firmware.....work well.!!!... |
ok thanks i gonna try with the new firmware denon are you on mac ? |
Hello, Sorry if I might of miss this but this is the small issue I'm having. When I load a song on virtual dj into the left deck it shows on my right deck and not on my left. Is there something I need to change"? |
