| Autor | - Topic: Database -> ID3 Tags - |
Ok, this is NOT a VDJ plug-in, but I decided to post here since this is the only place I might get some help. After browsing around these forums I decided to build a small application that will read the info of VirtualDj Database, and it will write the info back to the ID3 tags of the files, as it has been requested by many users. My application is 90% ready, but I have a small issue that I need some help: The application is written in VB.NET When I read the XML file, the "strings" I get back are always in ANSII format. That means that my application (for the moment) does not work properly with international charsets. I tried every way I could imagine and every code sample I found, but I could not succeed to convert this string in Unicode (which is the default way VB.NET handles strings) If someone can help me with that I would be really grateful.... Thanks! |
when this works you will go down in the annals of vdj history... lol |
if it will copy the bpm info from vdj to the id3 tag for bpm (and if it will work with both mpg2 video and mp4 video tags) I will start the drive to get you donations so you can upgrade to a PRO user, then put you in the VDJ Hall OF Fame! I might also suggest you have VDJ pay you a small stipend to build it into VDJ and include it in the next update! |
Ok, I bypassed my initial problem by writing my own XML-Parser... Now the app is working! :D For the moment it processes only mp3 files, but other filetypes will come soon... Right now I just have to do some beta testing... :P Edit: And YES, it does write BPM's ;) |
WMA Support added.... |
Ogg Vorbis support added Edit: No BPM support though since OGG Vorbis does not support it... Unless someone wants me to copy this info to another supported field... |
Flac support added. (Does even VDJ play .flac files? ) Edit: No BPM support though since FLAC does not support it... Unless someone wants me to copy this info to another supported field... |
sounds like Phantom is on a roll!!!! =) |
i think i will adopt him.... |
PhantomDeejay wrote : Flac support added. (Does even VDJ play .flac files? ) Edit: No BPM support though since FLAC does not support it... Unless someone wants me to copy this info to another supported field... Yes http://it.virtualdj.com/homepage/cioce/blogs/3263/_ENG__How_to_play__flac_files_on_Virtual_DJ.html |
APE support added. For now I'll stop adding other filetypes support. MP4 format support will come, but it needs a lot of work... Same rule goes for MPEG files! Now I need someone to tell me how to publish a beta here... (AFAIK links are not allowed by non-registered users) |
@PhantomDeejay. Good work dude. A few guys here will be well pleased with this little app you've created. |
wonder what i should call him after the adoption.... jimmy the greek has a nice ring/tag to it, lol. |
Beta 1 uploaded and waiting authorization! BTW: My real name is George, so "Jimmy the Greek" won't cut it... :p |
hehe, "geordie the greek" will do then "son".... lol |
Ok, it's UP! Please test it and report back any issues you may have.... Thanks! |
Cool, I'll give it a try later this afternoon :) |
Consultez la fin de ce message pour plus de détails sur l'appel du débogage juste-à-temps (JIT) à la place de cette boîte de dialogue. ************** Texte de l'exception ************** System.BadImageFormatException: Tentative de chargement d’un programme de format incorrect. (Exception de HRESULT : 0x8007000B) à VDJDbToTags.AudioGenie2.AUDIOAnalyzeFileW(String& FileName) à VDJDbToTags.AudioGenie2.AUDIOAnalyzeFile(String fileName) à VDJDbToTags.VDJDB2TAGS.Write_Tag() à VDJDbToTags.VDJDB2TAGS.Read_XML_5_T() à VDJDbToTags.VDJ2tagsMain.Button1_Click(Object sender, EventArgs e) à System.Windows.Forms.Control.OnClick(EventArgs e) à System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) à System.Windows.Forms.Control.WndProc(Message& m) à System.Windows.Forms.ButtonBase.WndProc(Message& m) à System.Windows.Forms.Button.WndProc(Message& m) à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Assemblys chargés ************** mscorlib Version de l'assembly : 2.0.0.0 Version Win32 : 2.0.50727.4918 (NetFXspW7.050727-4900) CodeBase : file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- VDJDbToTags Version de l'assembly : 1.0.0.0 Version Win32 : 1.0.0.0 CodeBase : file:///C:/Users/Domicile/AppData/Local/Apps/2.0/6JOKA341.GLA/MJ4O29KZ.TQW/vdjd..tion_83a23c14a46ea5bd_0001.0000_76107050e5fd51ee/VDJDbToTags.exe ---------------------------------------- Microsoft.VisualBasic Version de l'assembly : 8.0.0.0 Version Win32 : 8.0.50727.4918 (NetFXspW7.050727-4900) CodeBase : file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System Version de l'assembly : 2.0.0.0 Version Win32 : 2.0.50727.4918 (NetFXspW7.050727-4900) CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Version de l'assembly : 2.0.0.0 Version Win32 : 2.0.50727.4918 (NetFXspW7.050727-4900) CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Version de l'assembly : 2.0.0.0 Version Win32 : 2.0.50727.4918 (NetFXspW7.050727-4900) CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Runtime.Remoting Version de l'assembly : 2.0.0.0 Version Win32 : 2.0.50727.4918 (NetFXspW7.050727-4900) CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- mscorlib.resources Version de l'assembly : 2.0.0.0 Version Win32 : 2.0.50727.4918 (NetFXspW7.050727-4900) CodeBase : file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- System.Windows.Forms.resources Version de l'assembly : 2.0.0.0 Version Win32 : 2.0.50727.4918 (NetFXspW7.050727-4900) CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll ---------------------------------------- ************** Débogage JIT ************** Pour activer le débogage juste-à-temps (JIT), le fichier de configuration pour cette application ou cet ordinateur (machine.config) doit avoir la valeur jitDebugging définie dans la section system.windows.forms. L'application doit également être compilée avec le débogage activé. Par exemple : <configuration> <system.windows.forms jitDebugging="true" /> </configuration> Lorsque le débogage juste-à-temps est activé, les exceptions non gérées seront envoyées au débogueur JIT inscrit sur l'ordinateur plutôt que d'être gérées par cette boîte de dialogue. |
hi cel, sorry i don't speak or read french, but we would be interested to know what the above print out is showing and what it means for this plugin... thanks |
