Forum: Hardware Technical Support - Topic: NEW Hercules DJ Control Mp3 e2
Please post here all questions or comments about the hardware supported via HID or MIDI with Virtual DJ, Virtual Vinyl, Cue or AtomixMP3.
Hardware products
VirtualDJ Forum
Hardware Technical...
NEW Hercules DJ...
Autor - Topic: NEW Hercules DJ Control Mp3 e2 -
cioce
Moderator
Posted Thu 10 Sep 09 @ 8:47 am
09/10/2009 - Plug-and-Mix Decks For Next Generation DJs
Hercules Tools Up the Mac and PC Mixing Generation for a Pro-DJ flavour
London - September, 2009 - Hercules, the leader in portable DJing solutions for PC and Mac, has unveiled a brand new DJ controller packed with advanced mixing features for a pro DJ flavour. Highly portable and easy to use, the DJ Control MP3 e2 plugs into a PC or Mac via a USB port and instantly unlocks the potential in your playlists!
Retailing at £99.99, the Hercules DJ Control MP3 e2 works with all leading music file types (audio CD, MP3, WAV or WMA files for Windows®, AAC for Mac® OS), and gives all the control a DJ needs at their finger tips whether creating mixes, recording new tracks, designing the perfect playlist, or for DJing live, keeping the party going all night.
This new DJing controller succeeds the best-selling DJ Control MP3 (Edition 1) by Hercules, and comes with new features; a new, slicker and wider design for comfortable mixing, larger and more precise jog wheels, four navigation buttons (replacing the previous device’s joystick), increased space between the cross-fader and jog wheels, and more backlit buttons for mixing in low-light conditions.
Hercules DJ Control MP3 e2 makes mixing simple.
The Hercules DJ Control Mp3 e2 features two decks: The two jog wheels allow DJs to navigate through tracks, reduce or increase playback speed and to perform scratch effects. Thanks to the cross-fader and the two volume sliders, mixing tracks the professional way becomes easy with amazing results.
DJs can also add their personal touch by altering the music using the equalizer controls (bass, medium and treble ranges), adding (automatic) loops, multiple effects and even personal sounds, shaping music tracks to make them their own - the DJ Control Mp3 e2 even enables them to record their best creations.
Easy-to-use software, professional results
The DJ Control Mp3 e2 comes with its own easy-to-use software, VirtualDJ® 3 DJC, which analyses each track’s BPM (Beats Per Minute) and enables DJs to insert cue points (markers to launch a new track). The controller’s Sync, Pitch, Pitch Bend and Master Tempo controls adjust the track’s speed, allowing users to move smoothly from one track to another.
Fully portable
Compact in size (26.5 x 18.7 x 6.4 cm) and lighter than a laptop computer, the Hercules DJ Control MP3 e2 is the perfect portable solution. Powered by the computer’s USB port, it requires no external power supply. Its protective cover enables users to carry it safely, while its wide, non-slip pads ensure perfect stability, even in the most intensive use conditions!
The Hercules DJ Control MP3 e2 will be available in early October 2009, at the recommended retail price of £99.99 incl. VAT. So... all hands on decks!
The Hercules brand offers a range of solutions designed for beginner, amateur, advanced and professional DJs.
Technical information
* 2 jog wheels inspired by vinyl turntables
* 8 rotary switches
* 3 faders (sliders)
* 36 transport buttons
* 24 LEDs
System requirements
PC: 1 GHz CPU, 512 MB RAM, Windows® XP / Vista 32/64 bits, sound board and stereo speakers
Mac®: G4/G5 with a 1.2 GHz CPU or 1.5 GHz Intel® CoreTM Duo CPU, 512 MB RAM, Mac OS® 10.4
The full Hercules DJing range can be viewed online at http://www.hercules.com and http://www.HERCULESDJMIXROOM.com
http://www.hercules.com/uk/DJ-Music/bdd/p/110/dj-control-mp3-e2/
http://www.hercules.com/uk/news/bdd/news/49/titre/plug-and-mix-decks-for-next-generation-djs
dj-in-norway
Atomix Productions
Posted Thu 10 Sep 09 @ 11:05 am
Nice one ;)
Should be yet another popular controller from Hercules
bonabona
Limited edition user
Posted Sat 17 Oct 09 @ 7:33 am
nice stuff does he work great with virtualDJ home edition 5?
jakovski
Ultra-VIP Member
Controller Expert
Posted Sat 17 Oct 09 @ 7:55 am
The Home Edition only supports keyboard and mouse. Controllers can NOT be used.
Greets, Heiko
isrort
Professional edition user
Posted Sat 17 Oct 09 @ 12:00 pm
is it better than rmx? is it mapped in VDJ?
Haui70
Moderator
Radio Teamer
Posted Sat 17 Oct 09 @ 5:37 pm
Yes, the MP3 e2 is already native mapped.
The MP3 e2 is the next step after ther the MP3 ;-), but the RMX and Steel are the upper class!
See you
Haui
DeeJay_Verano
No license user
Posted Tue 17 Nov 09 @ 7:33 pm
hy everyone ...
i'm using Virtual DJ 3.1 and not the latest versions because it's has an amazing and a lot of sound effects. Starting with VDJ 4 .. the effects are limited ... i'm talking about limit because it have only 6 or 7 sound effects ...
but ... my question is this :
The Hercules DJ Control Mp3 e2 supports the VIRTUAL DJ 3.0 , 3.1 , 3.2 , 3.4 software ? [i mean , all v.3 versions ? ]
Or i have to install another Virtual DJ series or Tracktor or anything like that ?
I want to buy this stuff in a few weeks ... and i don't know if it's supporting VDJ V.3 Series.... I don't want to be disapointed , because i read some things on internet.
I'm waiting to reply someone to me ... here , or send-me a pm ...
A lot of thanks !!!
Keep'on rockin !!! ... Techno Rulez !!!
cioce
Moderator
Posted Wed 18 Nov 09 @ 1:54 am
This controller work starting from Virtual DJ 6.0.2 PRO
jpboggis
Senior Team
Posted Wed 18 Nov 09 @ 12:24 pm
Once you are a registered licensed user http://www.virtualdj.com/users/edit.html , you can download from a vast library of free add-ons including effects: http://www.virtualdj.com/addons/index.html
Many of these are only compatible with newer versions of the software.
There have been many enhancements to the software since v3, including support for new hardware such as the Hercules MP3 e2
rusek1993
Posted Fri 25 Dec 09 @ 6:14 pm
I from Poland. I have DJ Control MP3 e2 but I not have program. Help!
EDIT: This controller work starting from Tractor DJ or Dss DJ
(C)opyright Atomix Productions 2010
VirtualDJ Pro
VirtualDJ Basic
VirtualDJ Home
Demo Version
Bedienungsanleitungen
Sound Effekte
Video Effekte
Disclaimer
