Forum: VirtualDJ Plugins - Topic: Freeframe plugin sliders
Post here comments on the VirtualDJ Plugins (Audio effects, Video effects, Video transitions, Tools, ...).
Plug-ins are available for download by registered PRO License users only.
VirtualDJ Forum
VirtualDJ Plugins
Freeframe plugin...
Autor - Topic: Freeframe plugin sliders -
fran.cc
No license user
(iWall developer)
Posted Tue 15 Sep 09 @ 8:53 am
I'm testing VDJ with a FreeFrame plugin I'm developing for iWall (www.iwall.com.ar) and when running the plugin VDJ only shows the first three sliders of the four sliders implemented.
I also tested the plugin with Resolume and VJamm and the four sliders are accessible and working ok. Does somebody knows if there is a limitation in the number of sliders supported for FreeFrame plugins under VDJ?
Thanks
Francisco
SBDJ
Atomix Productions
Posted Tue 15 Sep 09 @ 1:00 pm
I don't recall VDJ ever displayed more than 3 freeframe parameter sliders; I suspect it is a limitation.
VIP DISCO & KARAOKE
Professional edition user
Posted Sat 10 Oct 09 @ 4:22 pm
I have tested the VJ plugin from Iwall and it would be good to have a vertical scroll option as opposed to Horizontal as it just seems more natural way to read the incoming texts, plus you can display more texts verticlly.
The polls do not work in the plugin.
Just some honest feedback!
But a good effort.
Thank you.
djcel
Atomix Productions
Posted Sat 10 Oct 09 @ 6:25 pm
@fran.cc
I guess you also have buttons on your plugin. In vdj the number of sliders displayed depends on the space available in the interface. If you use a skin with a higher height for the browser you will see more sliders.
tayla
Ultra-VIP Member
Firetext Representative
Posted Mon 12 Oct 09 @ 7:25 am
maybes this will help with your question, firetext is fully functional... also where you see the tiger you can make that transparent also to any degree you want to see the video below playing. hope that helps.....
Paul.
Firetext International.
