Forum: VirtualDJ Plugins - Topic: * TK Filter Help *
Post here comments on the VirtualDJ Plugins (Audio effects, Video effects, Video transitions, Tools, ...).
Plug-ins are available for download by registered PRO License users only.
VirtualDJ Forum
VirtualDJ Plugins
* TK Filter Help *
Autor - Topic: * TK Filter Help * -
billy_44
Limited edition user
Posted Fri 16 Oct 09 @ 12:46 pm
My TK Filter V2 is messed up. It says to use right click only but when you left click it changes the whole graph and the sound is distorted and the filter does not work anymore. How do I restore it to normal? I've tried re-installing it and it is still the same.
Thanks,
Billy
phoenix22
No license user
Posted Wed 25 May 11 @ 11:18 am
I have the same problem
kaleo
Ultra-VIP Member
Posted Thu 26 May 11 @ 10:19 am
No! it's not only right click but use ALSO right click!
With:
-> left click : you can change the Frequency (moving the mouse horizontally) of the effect and it's Bandwith (moving the mouse vertically)
-> right click : you can change the Frequency (moving the mouse horizontally) of the effect and it's Quality factor (moving the mouse vertically)
The quality factor is represented by the orange bar on the right of the display.
The higher it is the more distorsion you will have (the more the effect will be violent).
Reduce it by a right click and the mouse on the bottom.
Then, use only left click if you don't want to change the quality factor.
Kaléo.
DJ Michael wit an L
Premium Member
Posted Tue 07 Jun 11 @ 3:32 pm
HOW DO YOU GET OUT OF THE TK FILTER V2 AND GO BACK TO THE ORIGINAL SETTING HELP ME PLEASE
