| Autor | - Topic: Hercules RMX Plus......need a little help - |
First of all mad props to DjLaja for this mad skin. I only have one issue. I need to configure the 6 buttons to my liking. I should say I need to configure button #1 to the "Loop In" cue. Button #2 is set as "loop out", but when I click the drop down menu to configure button one the "loop in "option is not available. I'm sure I'm not doing something simple. Any help would be appreciated. Thanks! |
you can use the mapper to do that |
I am having the same problem. Can't seem to find the Loop in. the loop out is there. |
The functions were moved to the DJC menu, and no longer exist on the effect menu in VDJ 6 because they are not effects and they are functions ment specifically for controlers. You can try my edit of the RMX skin which will allow you to do that on the fly. http://www.virtualdj.com/addons/7329/RMX_Mod_Don_Houde.html Or you can do it in the mapper like mentioned earlier. |
