Forum: Hardware Technical Support - Topic: Midi Mapping with LCD Screen question
Questions or comments about the supported hardware by VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
For general troubleshooting and MIDI controller configuration, please see Config & Troubleshooting.
Hardware products
VirtualDJ Forum
Hardware Technical...
Midi Mapping...
Autor - Topic: Midi Mapping with LCD Screen question -
dydy1
Experienced pro user
Posted Thu 29 Oct 09 @ 2:12 pm
When I add certain command In the VirtualDJ v6 Denon DN-S1200 mapper or the DN-S3700 Is there a way also to map the LCD screen to show the command? example when I use the toggle option Is there a way to make the command show on the LCD screen for a few moment?
jpboggis
Atomix Productions
Posted Thu 29 Oct 09 @ 3:31 pm
Yes, you can use show_text to temporarily display some custom text:
show_text : display the text provided for a limited time (default 3 seconds). '$myvar$' in the text are replaced by the value of myvar. '$?myvar$' are replaced by 'on' or 'off'. '|' goes to new line. syntax: 'show_text "Shift:|Value=$?shift$" 5000ms'
E.g:
loop & loop ? show_text "Loop: On" : show_text "Loop: Off"
dydy1
Posted Thu 29 Oct 09 @ 3:55 pm
Thank you for the answer. What I meant to say Is how to display the different loop length on the LCD?
Another good question while I am at it. Is there a way to program a knob to function as a scroll knob when either the effects or a loop are off, and then acts as a parameter when the loop or the effect action are on?
jpboggis
Atomix Productions
Posted Tue 03 Nov 09 @ 6:00 pm
show_text can only currently show fixed text, but you could do something along the lines of the following:
E.g: For a loop out button (Where loop length can vary):
loop_out & loop 0.125 ? show_text "Loop: 1/8" : loop 0.5 ? show_text "Loop: 1/2" : loop 0.25 ? show_text "Loop: 1/4" : loop 1 ? show_text "Loop: 1" : loop 2 ? show_text "Loop: 2" : loop 4 ? show_text "Loop: 4" : loop 8 ? show_text "Loop: 8" : loop 16 ? show_text "Loop: 16" : loop ? show_text "Loop: On" : "Loop: Off"
For a button assigned to a fixed loop length, it's a bit easier:
loop 4 & loop ? show_text "Loop: 4" : show_text "Loop: Off"
To adjust effect parameter with a knob only while the effect is active:
effect active ? effect slider 1 : knobs_normal_function
(Replace knobs_normal_function with whatever it's currently mapped to.)
