Forum: Hardware Technical Support - Topic: How to create effect slider marker?
Questions or comments about the supported hardware by VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
For general troubleshooting and MIDI controller configuration, please see Config & Troubleshooting.
Hardware products
VirtualDJ Forum
Hardware Technical...
How to create...
Autor - Topic: How to create effect slider marker? -
dydy1
Experienced pro user
Posted Sat 31 Oct 09 @ 5:46 pm
How to create an effect slider marker script to show on the LCD screen of a Denon DN-S1200 for effect slider?
In the DN-S1200 In CD mode when player In CD mode, when effect is on and the effect slider button is manipulated as slider increases It feels up the outer section of the little circle icon on the LCD( Scratch Marker Icon) on LCD.
jpboggis
Atomix Productions
Posted Tue 03 Nov 09 @ 5:49 pm
You could probably do this by maping POS_SCRATCH to:
effect active ? effect slider 1 : jogwheel
However, the definition only allows one segment to be lit at a time.
dydy1
Posted Tue 03 Nov 09 @ 10:51 pm
Thank you. That works great.
