Forum: General Discussion - Topic: no power to my rmx
Discussions about VirtualDJ, Numark Cue, Numark Virtual Vinyl, AtomixMP3, ... and about DJing in general*
This a general discussion forum, please be polite and speak with respect. Before posting, please read the forum rules and FAQ. If you are experiencing technical issues or protection errors please contact Service Support.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
"No license user" cannot write personal Email, Facebook, Msn, Skype, MySpace, Phone number and any other personal contact details in the forum.
VirtualDJ Forum
General Discussion
no power to my rmx
Autor - Topic: no power to my rmx -
mr ranking
Limited edition user
Posted Sun 01 Nov 09 @ 12:00 pm
my rmx dont power up what could be wrong any help
djtouchdan
VIP Member
Premium Member
Posted Sun 01 Nov 09 @ 12:45 pm
When you say it isnt powering up, do you mean VDJ is recognizing it or you have no lights on when you plug it in?
If the later have you you tired a different USB cable, perhaps the original one is faulty??
Dazmax
VIP Member
Posted Sun 01 Nov 09 @ 12:49 pm
Hi mate
If its not powering up its also worth poping a USB memory stick or some other USB bus powered item into the port you normaly use and make shure the port is still providing power.
If the cable and the port are good it could be a case of off to the repair shop.
Daz
mr ranking
Posted Sun 01 Nov 09 @ 1:18 pm
has no lights play for about five mins then jus shut down
tried different cables nothing
mr ranking
Posted Sun 01 Nov 09 @ 1:21 pm
the control panel wont open up either
djtouchdan
VIP Member
Premium Member
Posted Sun 01 Nov 09 @ 1:29 pm
The fact that something is happening suggests it isn't a hardware fault.
I would suggest checking on the Hercules website that firstly your drivers are up-to-date. And also check your Firmware.
It is HIGHLY unlikely to be a fault in VDJ, but check out those other things and let us know how you get on.
mr ranking
Posted Sun 01 Nov 09 @ 10:30 pm
my usb ports work control panel dont open updated drivers did everything changed the cable still dont work if i right click on control panel hardware info and check for updates and exit i can click but select divice and open i cant
mistah_p
Professional edition user
Posted Mon 02 Nov 09 @ 8:47 am
mine has done that a couple of times..what ive done is re-installed the original disc for the hardware and software and used a different usb drive to do such.. and once it powered back up i just switched back to the primary port...
studio70554
Premium Member
Posted Mon 02 Nov 09 @ 3:06 pm
I'M thinking its something really simple try unplugging your RMX and restarting your computer.
Then plug your RMX after your computer is completely up. I have the same problem at times.
Before you haul your Rmx to the shop check to see if it comes on,with another computer.
mr ranking
Posted Thu 05 Nov 09 @ 10:27 pm
thanks everyone yep the rmx was shot dont know how it happened already sent it out looking for a backup cd player/mixer someone who knows about either numark cd mix2 / gemini cdm 3600 or make sugg on a budg need combo cd/mixer
mistah_p
Posted Fri 06 Nov 09 @ 8:33 am
when you say shot? so you had to send it back in or what,
mr ranking
Posted Fri 06 Nov 09 @ 9:30 pm
yep
