Forum: PC Version Technical Support - Topic: Can't monitor songs with Hercules RMX
Discussions about the PC version of VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
Hardware Support questions should be posted to the Hardware Technical Support forum. Before posting, please read the FAQ.
In case of problems or protection error please contact Service Support.
VirtualDJ Forum
PC Version Technical...
Can't monitor...
Autor - Topic: Can't monitor songs with Hercules RMX -
katzd
No license user
Posted Mon 02 Nov 09 @ 4:53 pm
Hi I recently bought the RMX and mapped it with Traktor Scratch Pro. Everything works fine, but when I try monitoring songs with headphones I get no sound. I have a feeling this may be due to my setup: My receiver (which connects to the speakers) is connected to my laptop, which is then connected to the RMX through the USB. There is nothing plugged into the back of the RMX's inputs and outputs. Is this the reason why this problem is occurring, or is it something else? Thanks for your help!
Haui70
Senior Team
VDJ Radio Team (Germany)
Posted Tue 03 Nov 09 @ 3:43 am
I guess you are in the wrong forum ;-)
Use this one if you use Traktor Scratch Pro!
http://www.native-instruments.com/forum/index.php
good luck
Haui
DJ Phatso
Experienced pro user
Posted Tue 03 Nov 09 @ 6:39 am
The file available at the adress below contains a document explaining how to configure Traktor with the Rmx, and mapping file for the MIDI.
ftp://ftp.hercules.com/sound/TDJS/current/TP_DJ_Rmx.zip
But, yes, it's always better to post on the appropriate forum ;-)
tayla
Ultra-VIP Member
Firetext Representative
Posted Tue 03 Nov 09 @ 7:53 pm
looks like you need to be the hercules rep phats, with all that stock you got... lol
