| Autor | - Topic: audio VCI-300 - |
ok i started with the VCI100, and wanted to move up, got the VCI300, but i prefer VDJ over itch. Problem, the 300 lights up, loads songs but won't play. can someone help me out??? |
I currently DJ using the VCI-300 and am looking into the VDJ world. I am trying to find out also if the VCI-300 will control Virtual DJ before purchase. Like the Karaoke features. I am a MAC user. Will there be a map for this controller? |
I think the problem is the don't correct setup of the audio card, look here http://it.virtualdj.com/homepage/cioce/blogs/3832/_ENG__Vestax_VCI-300_audio_setup_on_Virtual_DJ_6_0_2.html |
ok so now i have it working, but now my sound is distorted, seems like level r too high, even in the head phones, any idea??? |
why you want to move? i just ask, since the main differnece is the sound-card built in. I recommend buy a premium sound card better, since the sound card bult in in VCI-300 isnt that good, at least you have a mixer with xlr outputs. saludos. |
> ok so now i have it working, but now my sound is distorted, seems like level r too high, even in the head phones, any idea??? I had the same problem, try to tune headphone curve (labeled as I.F. Curve on VCI-300) |
