Forum: PC Version Technical Support - Topic: Buuzzzzz Sound !! At every mixed song in Automix Help Please
Discussions about the PC version of VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
Hardware Support questions should be posted to the Hardware Technical Support forum. Before posting, please read the FAQ.
In case of problems or protection error please contact Service Support.
VirtualDJ Forum
PC Version Technical...
Buuzzzzz Sound...
Autor - Topic: Buuzzzzz Sound !! At every mixed song in Automix Help Please -
devasty1
Professional edition user
Posted Tue 03 Nov 09 @ 11:00 pm
I can not use the automix feature at V6
Because every time in every mix when changes to the next song a horroble Buzzzzzzzzzzzzz sound appears . I can't belive it I bought this laptop thinking that was going to be better. Do you guys think that the videocard sucks or it its just the system combination or my bad luck I dont know what to do Im disspointed from this Laptop my other laptop with Half the of system spects works better.
Gateway P-7805u
Intel Coore duo 2.26 ghz
4 gb ram
Vista 64 bit
Nvidia G force 9800 M GTS
(when is mixing the 2 songs it is ok ,but the Buzzzzzzzz sound comes at the time when the softhware stops the song that was playin first
Please Some one can Help me It is very nessesary and important to be able to use the AUTOMIX
discobrian24
Moderator
Posted Tue 03 Nov 09 @ 11:49 pm
Wow thats an odd one.
TearEmUp
Senior Moderator
Posted Wed 04 Nov 09 @ 7:56 am
What sound card? Did you check for any IRQ conflicts?
devasty1
Posted Wed 11 Nov 09 @ 10:49 pm
I use Maya 44 and I never have any problems with any laptop to be exaxct 4 diff laps with no more than 512 gb of video dedicated annd never had that issue , I am sad because this new laptop I can not use autoplay and is very nessesary when U want to have a break or when you are at home and if If I want to let the music play Ohhh What are thos letters mean if I had check what??
discobrian24
Moderator
Posted Thu 12 Nov 09 @ 7:54 pm
Try taking the battery out of the lappy (of course make sure its plugged into the wall) and see if that helps.
devasty1
Posted Sat 14 Nov 09 @ 5:54 pm
IRQ conflicts? What that mean and how do I chek if I have thoase conflicts Ii is not the battery
