Forum: PC Version Technical Support - Topic: VDJ v6 + DJ Console RMX no headphones work?
Discussions about the PC version of VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
Hardware Support questions should be posted to the Hardware Technical Support forum. Before posting, please read the FAQ.
In case of problems or protection error please contact Service Support.
VirtualDJ Forum
PC Version Technical...
VDJ v6 + DJ...
Autor - Topic: VDJ v6 + DJ Console RMX no headphones work? -
ashlar
Professional edition user
Posted Wed 04 Nov 09 @ 1:07 am
Using VDJ 6.0.2 with the latest Hercules drivers for the DJ Console RMX (HDJS 3 Package) and can't seem to get the headphones to work on any of the aforementioned boards headphone jacks.
Any help would be greatly appreciated. I know this community rocks =)
FYI - everything worked fine (except the headphones) even with the keyboard mapper but I have since then switched to it's correct preset within the pull down.
Thanks kindly.
hawkmoon12
Posted Wed 04 Nov 09 @ 1:50 am
Same problem now i have installed Windows 7
ashlar
Posted Wed 04 Nov 09 @ 2:30 am
I actually got it to work by going into the config/sound setup and putting a checkmark in the "apply EQ on external inputs"...hope this helps.
Wow, i thought W7 was garbage and returned a brand new top of the line HP laptop on account of it having that hehe
update: make sure you click "apply".
hawkmoon12
Posted Thu 05 Nov 09 @ 6:04 am
I finally sorted my config out using asioforall, picking the rmx asio then going into asioforall and making sure the rmx was active works fine now :-)
mistafixit
Posted Thu 19 Nov 09 @ 11:13 am
Hi mate cant get my headphones to work properly on my dj console rmx any help? I am using vista
mistafixit
Posted Thu 19 Nov 09 @ 11:15 am
DJ Console RMX
Hi guys cant get my headphones to work properly any help? i am using vista
DJ Phatso
Experienced pro user
Posted Thu 19 Nov 09 @ 11:25 am
First thing to do, look at the audio configuration in VDJ:
- Input : None
- Output(s): Headphone > Master 1/2 - headphone 3/4
-Soundcard: DJ Console Rmx, > then check the box APPLY EQ ON EXTERNAL Sources
Then connect your speakers to output 1/2 on the back of the console, and your headphone to the headphone connector.
Simple as that.
mattynaughton
Posted Sun 22 Nov 09 @ 8:40 am
super duper! just worked for me
DJSoulman
Posted Sun 22 Nov 09 @ 11:33 am
ashlar wrote :
.......... with the latest Hercules drivers for the DJ Console RMX (HDJS 3 Package).
The latest Hercules drivers for the DJ Console RMX is HDJS_4..... now go get it! :-)
