| Autor |
- Topic: how can i save a mapper ? - |
Posted Wed 04 Nov 09 @ 9:37 am
This is my question ...i need to save my special vci300 mapper . can i ? - anoher one ...can i load a special mapper done by other user ? |
Posted Wed 04 Nov 09 @ 12:30 pm
Assuming you're using v6, mapper modifications are stored in the "Mappers" folder in your Documents\VirtualDJ automatically. You can back it up by making a copy of the file. Replacing that file with another will replace the mapping. |
Posted Fri 06 Nov 09 @ 5:31 am
hey man, do you got it working then, also prelistning headphone??? If so, would you tell me, how you managed it, and how you invert the mapper???
I hope you'll give an answer soon, i got a gig tomorrow.
greetzz |
