Forum: Hardware Technical Support - Topic: Virtual DJ v6.02 Hercules RMX
Questions or comments about the supported hardware by VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
For general troubleshooting and MIDI controller configuration, please see Config & Troubleshooting.
Hardware products
VirtualDJ Forum
Hardware Technical...
Virtual DJ v6.02...
Autor - Topic: Virtual DJ v6.02 Hercules RMX -
newradicals
Professional edition user
Posted Wed 04 Nov 09 @ 10:02 pm
I bought the RMX with the Virtual Dj(DJ Console) Edition of VDJ.
I have bought the 6.02 Pro version but it isnt working right.
I have looked through these forums but couldn't find a proper answer to my problem.
Basically, the programme has recognised the Hercules RMX Asio Soundcard and can play music through the RMX out of my speakers.
However I can't control or mix the music using the RMX Controller.
The RMX works well with the DJ Console condition now without any trouble.
I'd be greatful if anyone had any tips. Even very basic advice on what settings and stuff to put the RMX and VDJ on. I just got this a few hours ago and don't want it to be a waste of £100+
Thanks
bluntfusionn
Ultra-VIP Member
Posted Thu 05 Nov 09 @ 6:15 am
Is your Controller installed ? not only the Soundcard ?
Can you find it in the Device Manager ?
If it is go to Config - Mapper - Klick on the button right side of the word "Keyboard" and klick search again for devices.
Than the Herkules Must be found.
Please also Download the newest Hercules Driver from the Hercules Page and Run "Auto-Update"
jimmy b
VIP Member
Posted Thu 05 Nov 09 @ 11:50 am
Well first thing's first.
Have you got the latest Driver package for the RMX. If you haven't then download form here and install
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=1
