Forum: PC Version Technical Support - Topic: HELP!! how to use my headphone pluss speakers
Discussions about the PC version of VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
Hardware Support questions should be posted to the Hardware Technical Support forum. Before posting, please read the FAQ.
In case of problems or protection error please contact Service Support.
VirtualDJ Forum
PC Version Technical...
HELP!! how to...
Autor - Topic: HELP!! how to use my headphone pluss speakers -
DjMARZY
Limited edition user
Posted Fri 06 Nov 09 @ 4:45 am
hi
just lookin for some help setting up vdj to use headphones pluss my speakers.
i have 2 sound cards 1 built into the laptop and a external usb sound card.
i have read up on some topics of the same question but none of the solutions seem to work for me.
i have set my sound setup in config to:
inputs: none
outputs: headphones
sound card(s): 2 cards
sound card: primary sound driver
second card: usb audio
output chanels : master : first card / headphones : second card
as far as i can tell that looks fine to me but im only now gettin sound in the headphones.
i carnt see why this is not working for me.
if any 1 can help please do.
cheers
luke
DjMARZY
Posted Sat 07 Nov 09 @ 4:36 am
SOLVED THIS
finally got it working it was something simple.
if any 1 els has this problem just change ur sound setup in config to the same as above
but make sure that ur primary sound card is actually changed to tha name of ur sound caard
in this case mine was called realteck hd audio
inputs: none
outputs: headphones
sound card: primary sound driver <------------------ (MAKE SURE YOU CHANGE THIS TO THE NAME OF YOUR SOUND CARD)
dizon7th
No license user
Posted Thu 03 Dec 09 @ 1:04 pm
so you can use both jacks at the same time your usb headphone jack and computer headphone jack?
bryantpb
Professional edition user
Posted Fri 04 Dec 09 @ 12:39 am
What is the difference (in computer functionality) between primary sound card and "name of sound card"??
DJ Phatso
Experienced pro user
Posted Fri 04 Dec 09 @ 6:23 am
This refers to the default soundcard used by Windows.
In this case, if the USB audio was Windows default, the primary in VDJ, and he was selecting it also for the second card, then the Realtek was not used at all...
