| Autor |
- Topic: Best soundcard for use with time control vinyl? need something accurate enough for beat juggling - |
Posted Sat 07 Nov 09 @ 12:14 am
What's the best? I want to spend maybe 200-300
i have a maya 44usb and i think it might be the reason for the drift im experiencing. I've tried everything to fix it. Every setting, needles, tried new cables to each tonearm. using different drivers evverything.
I think it just may not be as accurate as my skill level. Are there any serious beat jugglers here? and if so what soundcard are you using? |
Posted Sat 07 Nov 09 @ 11:41 am
I think the Audio 4 DJ would be great for you.
It is from Traktor, so you can't go wrong. And you know how good Traktor is when it comes to scratching and beat juggling.
Its about 200-300.
So look around for the AUDIO 4 DJ. You will come across it.
Hope this helps.
Posted Sat 07 Nov 09 @ 4:06 pm
The soundcard has nothing to do with drifting. Soundcards make a difference in the output.. Some are lower and others sound higher and better. The drifting is something to do with the time code engine. (Needles, a Setting Etc) Version 5.2 works better.. |
Posted Sat 07 Nov 09 @ 7:20 pm
I've tried new serato vinyls, new numark vinyls. Needles. Higher sample rates, lower sample rates. everything! but im using 5.0 rev 5 i think. |
