Forum: Hardware Technical Support - Topic: X-Session Pro and Headphones??
Questions or comments about the supported hardware by VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
For general troubleshooting and MIDI controller configuration, please see Config & Troubleshooting.
Hardware products
VirtualDJ Forum
Hardware Technical...
X-Session Pro...
Autor - Topic: X-Session Pro and Headphones?? -
michael_faithless26
No license user
Posted Sat 07 Nov 09 @ 1:46 pm
i, im a starter ang bought myself an X Session Pro works great but the only things is i don't know how to plug my earphones into it. can you help me?? do the Cheap USB sound card works? or what is the Y Adapter?? HELP Im so confused.
Dazmax
VIP Member
Premium Member
Posted Sat 07 Nov 09 @ 2:03 pm
Hi mate
Are you using a laptop or a desktop PC?
Which version of VDJ are you running?
Daz
beardugo
Professional edition user
Posted Sat 07 Nov 09 @ 11:38 pm
usb will work fine
michael_faithless26
No license user
Posted Sun 08 Nov 09 @ 2:29 am
Laptop..
Virtual DJ 6
Dazmax
VIP Member
Premium Member
Posted Sun 08 Nov 09 @ 2:59 am
Hi Mate
Yes you can pick up a usb card to provide your master output and configure VDJ to use the laptops built in card for headphones or vice versa depending on what you find works best.
If you find VDJ works well for you, you might also want to look at some of the great little combination units out there. They will give you a mixer/controller/ sound card /all in one unit and many of them come with an LE copy of VDJ to get you started and registered.
best of luck
Daz
