| Autor | - Topic: Numark Cue and Denon DN-S3700's - |
Hi all, sorry if I duplicated a previous question but my searches never really satisfied my questions so here I am. Yes I am using the Cue version but they're identical and was wondering if anyone has any real world experience with VDJ/Cue and the 3700's? Such as, do they track well for looping, scratching etc... How do you access multiple cues? Also, since they have built-in sound cards how do you use the sampler since each deck is being controlled with a midi deck? AND, can you easily access (vie the 3700) the instant loop buttons such as 8/4/2/1 etc...? Here's my current setup. Cue 4.0 (yes I know I am waayyyy behind the times but I am most comfortable with it's record case) Numark DMC2 Dell laptop with a hi-def built in sound card Any input will be appreciated as I'd like to get some input before making the plunge only to discover I can't do what I am used to or want to do. Thanks. |
Hi, Did you get any input on another topic? Unfortunately I do not own the 3700s. Let me check for you and report back. |
im in the testing process i will give you feedback until friday some points have to be veryfied so just give me a second and stay at the old setup best regards dj-agua |
thanks guys, I'll look forward to any feedback people have to give. |
He is not using cue but they look like they work for him. I will invest in a set soon http://www.youtube.com/watch?v=Up9GDcsTKdM |
