Forum: Hardware Technical Support - Topic: NS7 works perfectly with 6.0.3 and both PC & MAC! - Page: 1
Questions or comments about the supported hardware by VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
For general troubleshooting and MIDI controller configuration, please see Config & Troubleshooting.
Hardware products
VirtualDJ Forum
Hardware Technical...
NS7 works perfect...
Seite : [>] [>>]
Autor - Topic: NS7 works perfectly with 6.0.3 and both PC & MAC! -
k_one
VIP Member
Numark Norway
Posted Tue 10 Nov 09 @ 10:01 am
Just wanted to let you guys know, since a lot of you have been waiting for this
Been beta testing this for a while now, and I'm very happy to report that performance is next to flawless :)
Enjoy!
pOpYDJ
Professional edition user
Posted Tue 10 Nov 09 @ 10:57 am
:-) Thanks for your info
Does the MIC and Start/Stop Time Knobs also work?
cu
pOpY
DjBoy01
Posted Tue 10 Nov 09 @ 11:28 am
Very exciting news, thank you for the report cannot wait till the update (it can be an early Christmas gift or an actual Christmas gift)
-- Well I see that the new version is actually out so early Christmas gift it is... Now I cannot wait to go home and test it out tonight
k_one
VIP Member
Numark Norway
Posted Tue 10 Nov 09 @ 1:56 pm
cu
pOpY
No, since 6.0.3 is a bug fix only, there aren't any new features released for the NS7 yet. I guess that'll be adressed in 6.0.4 ;)
DJ SUGAR
Posted Tue 10 Nov 09 @ 2:00 pm
Even tho i'm not a fan VDJ, have to say good work.. still there are some hiccups with pitch blend that is grossly noticeable when moving it up or down while playing a track
pOpYDJ
Posted Tue 10 Nov 09 @ 2:14 pm
cu
pOpY
Thanks for your answer.
Now i am waiting for 6.0.4 :-) *gg*
cu
pOpY
cstoll
Atomix Productions
Posted Tue 10 Nov 09 @ 5:37 pm
cu
pOpY
Start / Stop -- would need to add something *new* to make this happen ... will make note for next release
MIC/AUX -- we discussed this and would require making some change to the soundcard setup (*new*) ... ideas right now is to possibly add a dedicated NS7 Soundcard option or possibly make it an option to select from the INPUTs drop-down ... but it is on the list to look at.
This is most likely because the latency is set to low ... I spent a lot of time testing the various settings for the best 'sound' and came up with the following settings ...
PC - 512 samples in the Numark Driver Control Panel / VDJ Performance settings - Latency AUTO, Unchecked Safemode/Overclock, Scratch Optimized for Quality, Filters 11 with Filter Smooth checked, 48<->44 settings to 11 and Filter Smooth checked, Master Tempo on Fast ... these are pretty much Default Settings for VirtualDJ from install.
Mac - same VDJ settings. Now the NS7 settings, I could never get the Numark Driver panel to open so I could change the latency of the card. So, I had to run ITCH and make sure the slider was to the far right - think 20 was the number on their scale.
In both cases I found the performance very comfortable and functional ... I will admit that I could get the settings much better, but for a consistent sound and a universal setting for both platforms this is what I came up with.
kslimm0714
Posted Tue 10 Nov 09 @ 7:27 pm
still having the same problems as before with the sound problems with the platters on wtf... f virtual dj don't release 6.0.3 till you have all the bugs worked out
cstoll
Atomix Productions
Posted Tue 10 Nov 09 @ 7:40 pm
Then you have the latency set incorrectly ... if the latency is outside the bounds of the performance of your system then when the platters are ON you will immediately notice it .... The issue is resolved - you are trying to run your system beyond it's performance capabilities.
And if you didn't notice ... this thread was started by a Numark Representative ... so maybe you meant that Numark and VirtualDJ are incorrect for releasing a version that we both independently validate as working.
k_one
VIP Member
Numark Norway
Posted Tue 10 Nov 09 @ 7:49 pm
Also make sure that you actually upgraded to version 6.0.3.
I had to help a buddy earlier tonight who seemed to be stuck at 6.0.2 no matter how many times he installed the update.
Make sure you delete everything of VDJ (back up your library though), the software, folders containing mappers/skins/preferences etc and get rid of old reg files/plist files (depends if you're on mac or pc).
Then you should be able to make a clean 6.0.3 install.
I've been testing for several days now with a 2 year old MacBook (2.0 GHz Core2Duo, 2GB RAM) and I can run VDJ with the performance slider set to "Best" and latency at 2ms with no problems at all.
Please try a re-install, and if you still are experiencing problems please let me know so I can try to help you ;)
kslimm0714
Posted Tue 10 Nov 09 @ 7:55 pm
here are my settings the slider is set between fastest and best quality a lil more to fastest
sound car latency: auto/ safe mode and overclock is unchecked
scratch quality is checked
enhanced alforithm is checked
filter size: is 11
filter smooth is unchecked
48kHz-44khz
lowpass filter is checked
filter taps: is 11
master tempo
fast is checked
cstoll
Atomix Productions
Posted Tue 10 Nov 09 @ 7:59 pm
And using the Numark Driver Control panel what is the Latency setting there?
kslimm0714
Posted Tue 10 Nov 09 @ 8:10 pm
512 samples- 12.6ms/61.5ms
k_one
VIP Member
Numark Norway
Posted Tue 10 Nov 09 @ 8:34 pm
cstoll wrote :
k_one ... please clarify your settings ... you are NOT using video ... you are only doing audio - correct?
You would be giving a false impression of the performance capabilities without clarify how you use the controller. That is why I posted what I listed above.
That's correct cstoll. With the above mentioned settings I use it for audio only. It seems that my macbook is not powerful enough to do two tracks of video and the NS7 at the same time.
(Video however works fine in version 5.2.1)
kslimm0714, what are your computer specs?
it might be easier to determine the problem if we had some info about your system ;)
QUEWHAT62
Posted Tue 10 Nov 09 @ 8:46 pm
HEY GUYS I UPGRADED TO 6.0.3 ABOUT AN 1 1-2 AGO NS7 RUNNING NICE WITH 6.0.3 NO SOUND DROP OFF TURNTABLE DISK CONSTANTLY TURNING I EVEN GOT MY NS7 LATENCY TO 128MS ON NS7 AUDI CARD ...BEEN RUNNING ALL TYPE OFF VIDEO FORMATS WITH NO ISSUE SO FAR... MY LAPTOP IS A DELL PRECISION M4300 WINDOWS XP 4MEG OFF RAM AND 512MB DEDICATED VIDEO NVIDIA CARD ......SORRY TO HEAR ABOUT YOUR ISSUES
ONLY ISSUE I HAVE IS RUNNING VIDEO EFFECTS GET BLUE LINE OVER VIDEO EFFECT SCREEN AND THATS DUE TO NVIDIA CARD WITH WINDOWS XP THINKING OFF UPGRADING TO WINDOWS 7
QUEWHAT62
Posted Tue 10 Nov 09 @ 8:49 pm
SORRY FORGOT TO MENTION PROCESSOR INTEL T7500
QUEWHAT62
Posted Tue 10 Nov 09 @ 8:57 pm
HAVE YOU GUYS TRIED RUNNING DPC LATENCY CHECKER RAN IT AFTER INSTALL HAD TO DISABLE MY ANTIVIRUS AND FIRE WALL AND ALL PROGRAMS DOWN ON MY TASKBAR ALSO WIRELESS IS TURN ED OFF MY LATENCY IS STAYING SOLID ON GREEN NOT EVEN GOING ON YELLOW AT ON DPC LATENCY CHECKER HOPE THAT HELPS
kslimm0714
Posted Tue 10 Nov 09 @ 9:06 pm
i have toshiba satellite A135 laptop
1.72 dual core
2.00gb ram
32-bit operating system
DJ SUGAR
Posted Tue 10 Nov 09 @ 9:09 pm
How do you get the headphones to work?
cstoll
Atomix Productions
Posted Tue 10 Nov 09 @ 9:17 pm
You set the Output drop-down to Headphones.
Seite : [>] [>>]
