| Autor | - Topic: LEDS in Vci300 - |
hI : I have all my hot cue leds in green using my vestax vci300 ... with itch hot cue 1 is red - 2 blue and 3 yellow ... can we do something ? Thanks : Man-Tk |
I'll remake for colors ;) will upload tomorrow |
Thanks .... It would be good to know how to do it also ....thanks again |
This is not a hardware question ! |
Should be an easy thing. Go to your mapper settings of the vci-300. Enter a action for all the 'GREEN' leds in the list with 'nothing'. Then select the correct LED (for example in 'BLUE') and enter the correct action for lightning up. For example: 'hot_cue 1' for the LED in RED. (Take a look in the List - there are all the VCI Elements, also all the different colors of the leds) Greets, Heiko |
Ok ...done ...thanks |
Did it work like you wanted it ? Greets, Heiko |
Yes I saw him post it on spanish forum that he could map as he want, thanks Heiko ;-) I'm sure he is going to tell here by himself, just want you to know. |
jakovski wrote : Did it work like you wanted it ? Greets, Heiko Yes , thanks ...all is OK now ... BTW : I don't know who moves this post to here ...because this is not a hardware issue - |
It's an hardware discussion and general forum it's like a recycle bin sometimes, just to clean some topics... Anyway your mapper is now available ;) http://www.virtualdj.com/addons/9700/Vestax_VCI-300_with_correct_LED_mapper.html |
Dont know who moved it, but isnt a VCI300 a piece of hardware?? And u were askin questions about it??? I dunno:) |
right it fits here cause i wouldnt of found it anywhere else following that same logic as above |
the mapper fixes the led's but breaks the crossfader lol, I'll upload a better one later. |
DJ Cyder wrote : the mapper fixes the led's but breaks the crossfader lol, I'll upload a better one later. The crossfader is disabled . Sorry . |
VDJ can disable the crossfader without to delete from mapper, just in case you don't know... ![]() |
I have the crossfader for video . not audio ...thanks |
You can also do that without modifying a mapper - Set Options -> Crossfader to Disabled and tick Video -> Video crossfader linked to audio. Now the crossfader will act as a video crossfader only. |
