| Autor | - Topic: Recording @ Editing Mixes Question. Please help - |
Ok, i'm looking to do some recording and editing of my mixes obviously, i know how to use the record feature in vdj, but it doesnt give option to edit. Is there a program i can record and edit with while using VDJ? and if so, how do i set up? help will so much appreciated. My clubs need some demos. thx |
Look here |
Most will swear by the program Audacity for recording and editing (and it's free) but I used it a couple of times and it crashed on me and I lost the whole recording. Since you're a Mac user what you need is a program called Amadeus Pro... http://www.hairersoft.com/AmadeusPro/AmadeusPro.html Here are the reasons it's way better than Audacity: -It doesn't crash (and if it did there is a mode you can activate that will record a file real time that will save what you recorded up until the crash) -The interface is way more user friendly because you can 'scrub' through the track easily (i.e. fast forward & rewind) or easily jump to any point in the recording. -Unlike Audacity you don't have to mess with a complicated plug-in to convert to mp3 format. -It has a manual that is very thorough and easy to understand. -It uses hardly any CPU resources -It's designed specifically for Mac Mind you it costs like $40.00, but it's money well spent. To answer the other part of your question; to hook up your computer to record all you need to do is hook up a RCA to 1/8" Y adapter from the output of your mixer into the input jack of your Mac. Or, you can even just take a 1/8" to 1/8" cable going from your headphone jack directly back into your input jack. |
Cyder: Maybe you can help me. Searched the forums and haven't got an answer. I am trying to figure out how not to restart a master mix session on vdj 6, in case that you make a mistake during a session. Can you rewind a track, edit before the error and restart the recording session again? It's taking too long to record a master mix w/o having that feature to backtrack the song and edit. thanks djpj-vintage dj since 1981 |
bump? |
I highly recommend Sound Studio. I use it for recording, editing and mastering my sets. |
I've recently purchased a Hercules Mixer MK2 with VirtualDJ with Version 3.2 software. When i went to the Record Tab it said i couldnt. I the went to the upgrade software and downloaded VirtualDJ4.1 and i still have the same error. i've written a Ticket to the help desk and had no reply (Sunday 21st March) Please can someone help as i really want to record my mixes. Looking foward to your replies. thanks Rosebud |
Hello Rosebud, We always need the same information for all technical bugs: 1) Computer configuration - Computer model - CPU - RAM - Operating system with complete version number (for example Mac OS 10.5.8 or Windows XP SP3) - DJ Console series driver 2) What is the exact error message? |
