Forum: PC Version Technical Support - Topic: rmx crossfader problem
Discussions about the PC version of VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
Hardware Support questions should be posted to the Hardware Technical Support forum. Before posting, please read the FAQ.
In case of problems or protection error please contact Service Support.
VirtualDJ Forum
PC Version Technical...
rmx crossfader...
Autor - Topic: rmx crossfader problem -
jasonmonreal
Professional edition user
Posted Wed 18 Nov 09 @ 7:55 pm
To whom it may concern,
i just bought the rmx, but i found that the crrosfader is inverted. everything else works fine. when i but it on A (i hear B) when on B (i hear A)
can please somebody help.
i use virtual dj 6 and use it's own mapping.
thanks
Jason Monreal
DJ Phatso
Experienced pro user
Posted Thu 19 Nov 09 @ 12:18 pm
Can you test the crossfader using the following procedure:
http://ts.hercules.com/faqs/eng/her_eng_00353.pdf
As mention, the values should be 0 ( when on Deck A/Full Left) and 127 (when on Deck B /Full Right)
If the values are in reversed, then there is indeed a problem
jasonmonreal
Posted Thu 19 Nov 09 @ 7:07 pm
if the crossfader is 0% left 100% right is that bad? i got the mappings from virtual dj 6 they where already there.
DJ Phatso
Posted Fri 20 Nov 09 @ 6:29 am
Beside VDJ, what about in the MIDI test procedure ? Do you get the same results?
rdhrkns
Posted Tue 01 Dec 09 @ 1:12 am
I have the same using my DJ Console Steel under 6.0.x.
I will test later using the MIDI monitor as I'm not currently behind my setup.
rdhrkns
Posted Tue 01 Dec 09 @ 6:01 pm
Fader left, Deck 1 -> MIDI = 0
Fader right, Deck 2 -> MIDI = 127
However you will hear the song from deck 2 when fader is to the left and vice versa.
GadgetMan
VIP Member
Posted Wed 02 Dec 09 @ 5:20 am
Can you post your interface settings please. Inputs/Outputs/Soundcard.
Cheers,
Roy
rdhrkns
Posted Wed 02 Dec 09 @ 11:35 am
On my development system | Dell Precision 650 workstation
Inputs: None
Outputs: Headphones (master 1st card / headphone 2nd)
Soundcard: Soundmax Digital audio / onboard audio card
On my gig laptop | Sony Vaio
Inputs: None
Soundcard: Creative Soundblaster / onboard audio card (Sony Vaio)
Both setups show the inverted A : B / B : A crossfader problem.
GadgetMan
VIP Member
Posted Wed 02 Dec 09 @ 11:49 am
Inputs: None
Inputs: None
Ok, so you have a two sound card set up. I assume you have the outputs of both cards in to your sound system?
If you only have the Craetive connected, then you will hear nothing out of the onboard audio card?
Just out of interest, why do you not have the RMX selected as your sound card and have outputs 1&2 connected to your sound system?
And again, out of interest, what is your sound system? Mixer/Amp? Home Stereo? Active Speakers?
Cheers,
Roy
rdhrkns
Posted Wed 02 Dec 09 @ 3:43 pm
rdhrkns wrote :
I have the same using my DJ Console Steel under 6.0.x....
Normally I use my Reloop IE2, no issues running 6.x. The (old) DJ control Steel is sort of a backup. Just recently I've lend it to a friend to play around with it, and I noticed the odd behaviour. In the bundled 5.x version I received when buying the controller never had the issue. I scanned the forums for similar issues and thought I posted the issue under this thread as well, as it concerned a Hercules product as well.
Back to the issue;
Yes both are connected to a home stereo using the Dell. On the Vaio the Creative plugs into the amp on location. The headphones go either via the amp or I plug into the laptop directly.
Out of my interest, how does the soundcard setup cause the channel mixup on the crossfader ?
rdhrkns
Posted Tue 08 Dec 09 @ 12:54 am
When scouting some of the new skins I apparently set the X-fader curve response to some other then the 'normal' behavior. Loading a skin with a visual indication again. My eye caught this setting so I changed it back and voila ! All is normal again.
Dj 10-DIE
No license user
Posted Wed 09 Dec 09 @ 7:30 am
I've recently got the Numark Omni controller and using it with virtual dj 6 software bu I seem to be encountering the same problem as rdhrkns.
I can hear music from deck A even when the crossfader is positioned completely on deck B side and vice versa.
It seems like there is only one channel through which the music is being output through as I cannot cue a seperate song in my headphones.
I suspected the crossfader mapping was the issue but cannot seem to resolve the problem and unfortunately could not understand or relate to rdhrkns's last post- don't know if you or anybody else could help?
rdhrkns
Posted Wed 09 Dec 09 @ 8:03 am
Have a look at the CUE skin (http://www.virtualdj.com/addons/3196/CUE_RMX_by_cioce_variations.html). You can then easily switch between the different x-fader modes using the buttons in the center panel.
