Forum: Hardware Technical Support - Topic: Denon 3700 Mapping Issues
Questions or comments about the supported hardware by VirtualDJ, Numark Cue, Virtual Vinyl or AtomixMP3.
For general troubleshooting and MIDI controller configuration, please see Config & Troubleshooting.
Hardware products
VirtualDJ Forum
Hardware Technical...
Denon 3700 Mappin...
Autor - Topic: Denon 3700 Mapping Issues -
mixmasterdjhype
Professional edition user
Posted Thu 19 Nov 09 @ 6:20 am
Im almost there. I have both my midi channels set up properyly. I hear audio and see video using the sound cards on both players. But I only have control with the keyboard only. No buttons are lighted on the player while it is in midi mode. If I just use the keyboard everything works fine. Clearly I'm missing something here.
I would appreciate any tutorials that you may have. I'm constantly searching the boards and I cant seem to find my solution.
Im using a PC running 32 bit vista, with 4 gigs of ram, and im also using version 6.3 of vdj.
thanks
cstoll
Atomix Productions
Posted Thu 19 Nov 09 @ 7:02 am
When you put the units in MIDI mode what buttons do you press on the units?
