| Autor | - Topic: Xponent break beat fx keeps freezing on deck 1 - |
How do I get the break beat fx to stop freezing when I use it on deck 2 it freezes on deck 1. This is in XP. Also when will the drivers for windows 7 be available for Xponent? It will not work in windows 7 |
Whats are the specs for your laptop.. ? The newest drivers for the Xponent, you have to go to the M-Audio website. If you laptop has windows XP, You use XP drivers. |
lack1 wrote : How do I get the break beat fx to stop freezing when I use it on deck 2 it freezes on deck 1. This is in XP. Also when will the drivers for windows 7 be available for Xponent? It will not work in windows 7 Which FX do you mean? Beatgrid? As above, Windows 7 drivers would have to be supplied by M-Audio since it's their product. According to this page http://www.m-audio.com/index.php?do=support.faq&ID=14229394d3b14228e47c782542cb29c0 Xponent drivers for 7 have already been released? |
The fx is called breakbeat. When I use it on Delc 2 it also stops deck 1, O am trying to get the settings correct. |
Is it a VST effect? There is no native effect I can see called that. If it's a VST effect, then it's unlikely there is anything we can do about it. |
Thanks for the windows 7 driver...........for some reason I have a break beat fx in Xp But it is called just Break in Windows 7, anyway I got it fixed. Yhanks |
