Forum: Old versions
Topic: fatal error when searching for songs - Page: 1
speng1PRO InfinityMember since 2010
Can some 1 please advise me. Whenever I want to search for some tunes to play, I get a FATAL ERROR and it asks me if I want to repair. I have clicked repair and sent report but it always happens especially when I do a specific search and scroll down for certain songs and im concerned as it stops my music from playing and I have to reload the tracks. Not good if im performing live. Thanx in advance
Virtual DJ basic version
geposted Thu 11 Mar 10 @ 2:48 pm
please don't ask the same question multiple times in different places..
PC Technical Support IS the better place for your question, but now I've already replied to your question once..
so I refuse to do it again ;-)
geposted Thu 11 Mar 10 @ 3:23 pm
Im sorry about that. My reason for that was I placed it in the other section before realizing I should have put it here 1st but im new to this forum so forgive me LOL.
geposted Thu 11 Mar 10 @ 3:25 pm
Its a vd error and only does it when I do a particular search. I have taxi rhythem in my database and when I type taxi rhythem in and then scroll down the list, it always does it at the same point (FATAL ERROR) if thats any help.
geposted Thu 11 Mar 10 @ 3:29 pm
hmmm.
I'm thinking this might be one of those issues where we need a Teamer..
Havent seen this problem before. I know their was a "search crash bug" at some point, but I think? that was around before basic came out (and it didnt relate to specific searches)..
BTW, which version of VDJ Basic are you running? 6.07? 6.05?
Are you using an external or internal hard drive to store your music? (or both)
geposted Thu 11 Mar 10 @ 3:59 pm
Hi, Im using VD 6.07 and have a 500gb laptop drive (seagate) storing my music. It only has 120gb of tunes on it ?
geposted Thu 11 Mar 10 @ 4:05 pm
djcelPRO InfinityModeratorMember since 2004
Which version of MS Windows?
Can you post the crashguard report here SVP.
Does this point correspond to the video results of netsearch?
geposted Thu 11 Mar 10 @ 4:18 pm
Im using window 7.
All it says is:
A fatal error has occured.
Virtualdj can try to automatically recover from the crash.
Just click on recover and everything should be fine.
Recover or shutdown.
Send report.
I dont use any video
Hope that helps :)
geposted Thu 11 Mar 10 @ 5:55 pm
But you have a report in my documents\virtualdj
geposted Fri 12 Mar 10 @ 12:12 am
geposted Fri 12 Mar 10 @ 10:04 am
sorry for the late reply, been at work.
Thanx, here is the crash report:
Crash ID=754cacae (date=1003080945, version=6.0.7 Basic, build=607, thread=CoverFlow, dump=880646ff, excode=c0000005 (1,64616c7a))
I have no idea what this means but even today I did another search and it happened again
geposted Fri 12 Mar 10 @ 3:52 pm
Apparently you have a corrupted cover in one of the id3tag of the listed songs when you search for "taxi rhythem " or a bad cover download
Can you find this corrupted song and send me it. I really need it !!!
Now verify it by going into the config->browser->Cover : tell me which option you have.
then set "Don't search" , and then test again
geposted Fri 12 Mar 10 @ 4:45 pm
Hey. Wow. I just done what you said and NO MORE ERROR. Thats great. Unfortunately, I have no idea which one would have caused it and also it has happened on a few other searches but by the time I can see which one caused it, the fatal error would kick in. I will run a load of searches and see how it gets on. Thanx. That has really made my day :) Will report back shortly.
geposted Sat 13 Mar 10 @ 4:05 am
unfortunately I have just had the same problem. I was in a folder searching away and playing some music when all of a sudden, FATAL ERROR pops up again and I had to hit recover shutiing everything. Here is the crash guard report. I done what you asked above but still no luck.
Crash ID=753bacae (date=1003131035, version=6.0.7 Basic, build=607, thread=CoverFlow, dump=880646ff, excode=c0000005 (1,64616c7a))
geposted Sat 13 Mar 10 @ 4:40 am
I also just noticed that when I went back into config and browser, the option you told me to set as dont search had gone back to search mode so I think that may have been the problem. Will report back again later :)
geposted Sat 13 Mar 10 @ 4:42 am
130584PRO InfinityMember since 2008
Hi I am having the same problem. Im getting a fatal error report. My crash report is :
Crash ID=0052bd97 (date=1301160153, version=7.0.5b Pro, build=380, thread=Main, dump=8500ebe9, excode=c00000fd (0,32000))
Crash ID=76c1e777 (date=1304202249, version=7.4 Pro, build=453, thread=Main, dump=81792820, excode=c0000006 (0,4850028))
Freeze (date=1304202249, version=7.4 Pro, build=453, thread=Screen)
Crash ID=771fe777 (date=1304280136, version=7.4 Pro, build=453, thread=Main, dump=81792820, excode=c0000006 (0,3b50028))
Crash ID=771fe777 (date=1304280151, version=7.4 Pro, build=453, thread=Main, dump=81792820, excode=c0000006 (0,3980028))
Crash ID=771fe777 (date=1304280156, version=7.4 Pro, build=453, thread=Main, dump=81792820, excode=c0000006 (0,3940028))
Crash ID=771fe777 (date=1304280205, version=7.4 Pro, build=453, thread=Main, dump=81792820, excode=c0000006 (0,29c0028))
Freeze (date=1304280205, version=7.4 Pro, build=453, thread=Screen)
Crash ID=771fe777 (date=1304280206, version=7.4 Pro, build=453, thread=Main, dump=81792820, excode=c0000006 (0,39c0028))
Freeze (date=1304280206, version=7.4 Pro, build=453, thread=Screen)
Crash ID=771fe777 (date=1304280206, version=7.4 Pro, build=453, thread=Main, dump=81792820, excode=c0000006 (0,5f80028))
Crash ID=771fe777 (date=1304280207, version=7.4 Pro, build=453, thread=Main, dump=81792820, excode=c0000006 (0,5c60028))
Freeze (date=1304280207, version=7.4 Pro, build=453, thread=Screen)
Crash ID=771fe777 (date=1304280207, version=7.4 Pro, build=453, thread=Main, dump=81792820, excode=c0000006 (0,5d40028))
Crash ID=771fe777 (date=1304280208, version=7.4 Pro, build=453, thread=Main, dump=81792820, excode=c0000006 (0,3b20028))
Freeze (date=1304280208, version=7.4 Pro, build=453, thread=Screen)
Can you help me please. I am using virtual dj 7.04 pro
geposted Sat 27 Apr 13 @ 9:40 pm
i have same problem with us plz anyone help me i uaed virtualdj 5.0 :(
geposted Fri 06 Dec 13 @ 3:59 am
VirtualDJ v5.0 is a very old and out of date version of the software. There have been many changes and improvements and bug fixes to the software since then (See http://www.virtualdj.com/wiki/VirtualDJ_History.html ) - We are now on v7.4.1
Please register your serial number to your account http://www.virtualdj.com/users/edit.html and then upgrade to the latest version: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ then please support the software and its future development by purchasing it: http://www.virtualdj.com/products/comparison.html (Especially if you are a working DJ and are making money as a result of using it at your gigs.)
If you are using VirtualDJ for home use only without MIDI controllers/timecode/video, then you can download and use the latest VirtualDJ Home FREE from http://www.virtualdj.com/download/free.html - This version can be used completely free of charge for non-commercial home use (It may not be used a DJ gigs where you are being paid.)
If you still have problems when using the latest v7.4.1 then please contact support for further assistance: http://www.virtualdj.com/contact/index.html
geposted Fri 06 Dec 13 @ 5:56 am
This is the fatal error message I am receiving and I cannot connect my typhoon dj controller. Can you help
Crash ID=05288dcb (date=1405171943, version=7.0 Pro, build=342, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
Crash ID=03d18dcb (date=1405171944, version=7.0 Pro, build=342, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
Crash ID=03658dcb (date=1405171944, version=7.0 Pro, build=342, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
Crash ID=03628dcb (date=1405171945, version=7.0 Pro, build=342, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
Crash ID=052d8dcb (date=1405171945, version=7.0 Pro, build=342, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
Crash ID=03c98dcb (date=1405171953, version=7.0 Pro, build=342, thread=Main, dump=8b088b51, excode=c0000005 (0,0))
geposted Sat 17 May 14 @ 7:02 pm
cover is download exact match
virtual dj pro 7
geposted Sat 17 May 14 @ 7:35 pm
87%
