I have a Korg PadKontrol Midi Controller, which I use w/ Virtual DJ for sampling. First, why not add this Midi Controller to your program for easy plug/play use. I am of the believers who like to plug and play right out of the box. Right now, I would have to configure every pad, etc to make it work all in sync. Secondly, it would be nice to have # of sample pad on VDJ sampler section. For example, when I am trigger sampling on my Korg PadKontrol, it would be easy to sample with say #3 pad, then find out on VDJ sampler which #sample is on (Korg has 16 sample pads, VDJ only has 12. (which makes it the more easier to incorporate Korg PadKontrol into your program for easy plug and play...like the Numark NS7 and Serato Itch program). Thanks for listening, please let me know if anything is going to change for the future).
geposted Sun 21 Mar 10 @ 8:57 pm
If you like plug and play right out of the box, may I suggest you buy hardware that is compatible with the software. may I suggest the Korg Nanopad. Small, light, cheap. It has the same amount of sample banks as VDJ and already has a mapper. It's a great little product. Other then that, you might try mapping your Korg yourself. I've done a bit of mapping with VDJ and it isn't all that tough.
CRash
CRash
geposted Sun 21 Mar 10 @ 10:23 pm
hello
i also have a padkontrol but i have no function
how did jo make it have you write a xml datei for it?
don't know how i should go on
can you put ypur mapper in the download sektion on this website?
geposted Thu 27 May 10 @ 11:45 am
Ok heres 1 thread I had with some things you should know, http://www.virtualdj.com/forums/127989/Hardware_Technical_Support/Korg_nanoKontrol_users____________.html,
and this 1 will tell you how to make the buttons respond how you want them to http://www.virtualdj.com/forums/128082/Hardware_Technical_Support/another_minor_question_for_the_pros_.html, I really should make a video on how to do this cause it does suck setting it up at first but in the end its sooooooo worth it!!
OPPS just saw that this is for the PADkontrol not the nanokontrol, sorry fellas.
Holla back
Huey
Holla back
Huey
geposted Thu 27 May 10 @ 8:04 pm
