i just got the maya 44 usb sound card. i came the virtual dj and downloaded the timecodes. and burned them. things work it just that the program act really weird. When i press play everything is cool but if i try to pause it the song will go nuts! speed up rewind . play backwards. it also do this if i try to set a cue point using the cd deck. I need help fixing this!
the program also acts weird when i load up new songs into the inactive deck . it will cause the other side to make a weird distorted noise.
my quality is 100% for both sides
geposted Fri 23 Jul 10 @ 1:25 am
