I just bought the Stanton SCS3 and only the mixer works. Everything lights up but it dosent work with the software. Could someone HELP ME!!!
geposted Mon 13 Sep 10 @ 8:35 pm
are you using the power adapater with the scs3m?
did you plug in each device individually first, so that the computer could properly recognize them?
if so, have you tried using the scs3d, alone and see if recognized in VDJ.
Also, here's a helpful hint, when the scs3ds load in VDJ they don't go to a mode. You have to hit the vinyl button to get them to that mode after opening VDJ.
geposted Wed 15 Sep 10 @ 9:01 am
Hi !
I got 1 Stanton SCS.3D and 1 SCS.3M that use to work properly with VDJ 6...
I installed VDJ 7 and now my SCS.3M (mixer) don't work anymore
I tried to "reinstall it" but nothing worked out...
The SCS.3D (turntable) work and the 3M is recognize in the mapper section but i can't even try to re map it. When I use the key learn button, there's no way any button on the mixer is recognized...
Please Help ME!
Thanks
DJQC
Please Help ME!
Thanks
DJQC
geposted Thu 09 Dec 10 @ 11:02 am
I'm sure this will begin a massive, "the forums isn't the place for support" debate.
I would like to calm any concerns that you have that you are alone, and that this is something YOu are doing. I can tell you that it is not. I have been using the SCS3 with vdj since triple 9 dropped the first definition and mapper, and have never had so much difficulty, as I do in VDJ 7. It(scs3m) frequently just goes black and I have to un-plug, both from computer and power, and then re-connect everything and open. It acts like, something is fooling with the power that gets sent to the 3m.
Seems to be more frequent on the mac.
Sorry for the poor description, I wish I had all day to sit and test and meticulously document every key-stroke and midi cc, but I don't. All I know is that 'It ain't workin right."
I am experiencing the same thing you are. I'm sure it will get straightened out.
geposted Thu 09 Dec 10 @ 2:06 pm
Hi All,
Just posted my problem elsewhere but thought i wouild give it a mention here as well.
SCS 3m not working with VDJ 7.
Have a look at the video i posted on a mates youtube account, think it demonstrates the problem rather well.
http://www.youtube.com/watch?v=h2l3U6qdzXQ
Thanks
Daz
Thanks
Daz
geposted Thu 03 Feb 11 @ 9:13 am
can you try to mapp something with the simple midi wrapper?
geposted Thu 03 Feb 11 @ 3:51 pm
Sorry not really sure what you mean here... However if you want to respond i have 2 line of support going "My Fault".
Think it best to keep it in one location. Will use this Post from now on....
https://virtualdj.com/forums/137892/General_Discussion/Stanton_SCS_3m_System___Virtual_Dj_-_need_some_help_setting_it_up.html
Thanks
Daz
geposted Wed 09 Feb 11 @ 5:08 pm
