I'm running 6.1.2 on Windows 7 (32bit) and DirectX 11. I'm an old time VJ user and Engineer. However, after several "re-installs" the karaoke plugin still can not locate the d3dx9_33.dll. Should I go back to Directx 9 instead of 11 ? Everything else works as normal.
geposted Sat 18 Sep 10 @ 4:21 pm
You dont have to go back to DX9. Just google for the .dll, download it and copy to the proper dir. (Don't remember if it had to be copied to the system_32 or the program dir). Had the same problem some time ago.
Martin.
Martin.
geposted Sat 18 Sep 10 @ 5:40 pm
http://www.virtualdj.com/forums/95136/Virtual_DJ_Plugins/Plugin_not_working__Controls_not_showing__DX_File_Missing_______Read_this_before_posting_____.html
DX9 updates will install alongside DX11 fine.
geposted Sat 18 Sep 10 @ 8:12 pm
I am having the same problem win 7 64-bit, should I just download from the links in the above link and install?
geposted Mon 20 Sep 10 @ 2:09 pm
It did make the karaoke work for me thanks.
geposted Mon 20 Sep 10 @ 3:21 pm
Hi to all,
Here is the d3dx9_33.dll : http://www.d3dx9.net/download-missing-d3dx9_33-dll/ and http://dllcentral.com/d3dx9_33.dll/9.18.904.0015/…download it and then extract the downloaded zip file to the system32 folder which is located in windows folder (that is located in your main drive which contains the installed windows)
geposted Mon 27 Jun 11 @ 1:18 pm
Old topic.
The best way is to install the latest DirectX runtime updates. That way you get everything you need.
geposted Mon 27 Jun 11 @ 3:08 pm
