Topic: Mapper Commands
Is there a list of mapper commands and their function. I'm fairly new to this and I would like to know what each command does then I can correctly map my VMS4. I know some commands are quite obvious but not all. Can someone please help?
geposted Mon 20 Sep 10 @ 2:03 pm
geposted Mon 20 Sep 10 @ 2:24 pm
Thanks! That's exactly what I was looking for.
geposted Mon 20 Sep 10 @ 5:54 pm
How can I remap my Numark mix track pro 3 to skip 16 beats or a bar or phrase. I'd like to use the pitch bend buttons on the controller but cannot figure out how to do this. The command I'm wanting to use is seek +16.
I've sorted it. Phew....
geposted Thu 23 Mar 17 @ 3:36 pm
In future, please do not bump threads over a year old (this one is from 2010). Start a new post.
geposted Thu 23 Mar 17 @ 5:44 pm
seek +16 is indeed a valid VDJ Script action that will move the track 16 beats forward while the button is held (repeated action)
You can also use goto +16 (or goto -16) to move the track 16 beats forward (or backwards) if you want to perform the action just once while the button is held down.
See how you can map a button on your controller here http://www.virtualdj.com/manuals/virtualdj8/settings/controllers.html
geposted Fri 24 Mar 17 @ 3:03 am
