On my TotalControl I have mapped the Sample Wet/Dry knob (ENC_SAMPLEVOL) to control "filter" and it works fine.
Now I would like to assign the button under it, REC (SAMPLEVOL) to turn the filter back to zero.
This way I can do a filter sweep and then hit the button on the beat to turn the filter off.
What would the command be to turn the filter off? I am using the built-in filter on VDJ 7, not an add-on effect.
Thanks!
Thanks!
geposted Mon 13 Dec 10 @ 10:36 pm
"Deck 1 filter 50%"
Good Day
Huey
Good Day
Huey
geposted Tue 14 Dec 10 @ 6:37 am
Thanks, that works fine for deck 1, but how do I get it to work with all 4 decks?
geposted Fri 17 Dec 10 @ 9:01 pm
Lol!!
"Deck 1 filter 50%"
"Deck 2 filter 50%"
"Deck 3 filter 50%"
"Deck 4 filter 50%"
Good Day
Huey
"Deck 1 filter 50%"
"Deck 2 filter 50%"
"Deck 3 filter 50%"
"Deck 4 filter 50%"
Good Day
Huey
geposted Fri 17 Dec 10 @ 11:15 pm
to assign to a controller, simply map as ..
filter 50%
No decks. Your controler will do the rest.
filter 50%
geposted Sat 18 Dec 10 @ 6:17 am
To reset it on all 4 decks simultaneously, use:
Deck 1 filter 50% & Deck 2 filter 50% & Deck 3 filter 50% & Deck 4 filter 50%
geposted Sat 18 Dec 10 @ 10:22 am
btw i was wondering if there is code available to mute the filter as long as i turn the slider to a desired position. I mean i would like to use this effect by starting from 10% and ending to 50%.
Just like an effect parametr that could be adjusted before you engage the effect.
geposted Sat 18 Dec 10 @ 6:17 pm
the SOUND INSURGENT wrote :
Lol!!
"Deck 1 filter 50%"
"Deck 2 filter 50%"
"Deck 3 filter 50%"
"Deck 4 filter 50%"
Good Day
Huey
"Deck 1 filter 50%"
"Deck 2 filter 50%"
"Deck 3 filter 50%"
"Deck 4 filter 50%"
Good Day
Huey
TNX guy
geposted Sat 03 Nov 18 @ 8:01 pm
I am trying to set a button to reset the filter by mapping "Deck 1 filter 50%" but the thing is i want the filter to reset like the pitch reset with a certain speed, unlike suddenly going back to 50%. Is it possible?
geposted Fri 13 Aug 21 @ 11:12 pm
I am trying to set a button to reset the filter. I succeeded by mapping "Deck 1 filter 50%" but the thing is i want it to reset like the pitch with a certain speed unlike suddenly going back to 50%. Is it possible?
geposted Fri 13 Aug 21 @ 11:16 pm
