The software recognizes my controller, but sound only comes from one speaker. I got a splitter for my speakers so that they can be both output channels. Still, only one speaker works. Also, whenever I load one track, all music stops and I must reset both tracks to get anything to play. Also, the mixers, and volume controls do nothing. The speakers I own are simple speakers found with a desktop. I am running with these specs:
Inspiron 530S
Gentuine Intel CPU
2140 @ 1.60 GHz
3GB RAM
32-bit OS
I don't know if you'd need my speaker specs but here:
Realtek HD Audio
3.5 mm Jack
24 bit, 48000 Hz
I called Numark and he said I needed to update VDJ LE and which I did and it still doesn't work...
Any solutions??
Inspiron 530S
Gentuine Intel CPU
2140 @ 1.60 GHz
3GB RAM
32-bit OS
Realtek HD Audio
3.5 mm Jack
24 bit, 48000 Hz
Any solutions??
geposted Tue 21 Dec 10 @ 10:35 am
I got one to but mine doesnt even pick my Mixtrack Pro up, Says "The controller has not been detected. Please plug in the controller and restart Virtual DJ". It is plugged in and reinstalled it 3 times... Any advice?
Thanks
Thanks
geposted Thu 23 Dec 10 @ 7:02 pm
the same experience: original version from CD and also with version 6.1.2downloaded/installed.. (PC Win XP and win Vista too) THE CONTROLLER HAS NOT BEEN DETECTED :-(
geposted Thu 30 Dec 10 @ 9:21 am
I shure hope someone comes with an answer.
Just bought the mix track pro, installed VDle; Same problem!
geposted Thu 30 Dec 10 @ 11:45 am
Is this problem still not solved?
I have the same issue, just bought myself the Numark Mixtrack Pro, but I can't do anything with it.
The computer recognizes the hardware and everything's fine, but when I run the Virtual DJ LE it loads untill: Error: "The controller has not been detected. Please plug in the controller and start VirtualDJ again."
I already tried to plug the USB-cable in all of my ports. -> No effect
Re-installed everything the correct way like 1000-times. -> No effect
Hopefully we find an answer...
Already thanks in progress
geposted Thu 10 Feb 11 @ 11:22 am
There is already a thread running on this:
https://virtualdj.com/forums/139703/Hardware_Technical_Support/Mixtrack_Pro_Help_.html
geposted Thu 10 Feb 11 @ 2:39 pm
