Forum: Old versions
Topic: Help...PLEASE!!!
I have recently bought a Numark Mixtrack DJ Controller and came here and bought virtual dj pro 7 software and everytime i open up the pro7 with my controller it sends me a message saying i could only play for 10 minutes...what do i need to do? any help and guidance would be great :)
THANKS...
geposted Thu 27 Jan 11 @ 4:05 pm
It sounds like you are still using a limited version of the software.
Please ensure that you have installed VirtualDJ Pro - You can download it from https://virtualdj.com/download/updates.html
Once installed, make sure that you run it using the correct VirtualDJ Pro icon found in Applications.
If you have shortcuts on your desktop and/or dock, these may still be pointing to the limited version.
