It connects but gives a Error could not load skin. Where do i find skins and how do i down load them. Like the remote so far.
geposted Sun 30 Jan 11 @ 9:42 pm
iPhone skins you can download from here.
https://virtualdj.com/addons/skins.html?category=iphone
iPhone skins must be saved as zip files in MyDocuments/VirtualDJ/Skins/iPhone Folder. In case this Folder does not excist you must create it first.
In case the automatic skin installation (after downloading) gives you an installation error 7, ignore it, it probably has already install it.
Once you download the skins you need, goto Config,iPhone/iPad Tab and choose, Upload New skin. Choose the skin you need and press OK.
Sometimes an iPhone skin might fail to load due to limited iPhone Memory or due to the large size of the skin itself. This usually happens to older generation iPhones.
geposted Mon 31 Jan 11 @ 12:23 pm
