I use VirtualDj LE and I decided to try out the 20-day free trial. it said to restart so i did. When I go back in, nothing happened, and when I go to try it again then it said that it was already used. What should I do?
geposted Tue 08 Feb 11 @ 3:44 pm
I will be watching this thread cuz I had the same problem on my macbook pro.
geposted Tue 08 Feb 11 @ 3:48 pm
I will be too. I'm having the same problem on my pc.
geposted Wed 09 Feb 11 @ 10:02 pm
All the support staff will tell u 2 do is download the home free and try the trial there cuz it will give u 10 minutes of Pro features....That's what they did to me.
https://virtualdj.com/forums/142541/MAC_Version_Technical_Support/VDJ_LE___Mixtrack.html
Hell I'm at the point to where I'm just thinking about spending my money on traktor. As much as I love using VDJ because I feel like it is simpler to use and I enjoy it more but why pay the money to upgrade when my mixtrack isn't working properly with the LE version. So why buy the pro version until I know that the issues are corrected.
geposted Thu 10 Feb 11 @ 1:36 am
Sounds like you've used the VDJ trial in the past.
As you've been told once the trial expires, you can continue to trial using VDJ Home which allows pro features for 10 minutes in each session.
geposted Thu 10 Feb 11 @ 2:37 am
I have never used a trial in the past. I downloaded home free about 2 weeks ago and I never hit an upgrade button because I knew I was gonna do it once I got my mixtrack.
geposted Thu 10 Feb 11 @ 11:09 am
Perhaps home free does something to the trial period then. Your best bet is to contact support via ticket or phone.
geposted Thu 10 Feb 11 @ 2:38 pm
If you have installed the Home version then the LE 20-day will not activate as you already have the 'trial' version installed - which is the HOME version.
geposted Thu 10 Feb 11 @ 7:08 pm
