i have just brought a hercules dj control mp3 by the looks of things one of the mk1's. I just brought it thinking i could just learn how to do it but it uses a really old vitual dj any way of getting vitual dj 7 to work on it? Im not going to lie not the best with computers but have looked all in the config at the top and just cant seem to find away? cheers sam
geposted Thu 17 Feb 11 @ 5:01 am
The home free version of VDJ7 will work with your controller for 10 minutes only for trial purposes. You will need to upgrade to VDJ 7 Pro to have full external controller support.
Once you have registered your LE version on this site (if your controller came with the CD) you will get a discounted price for the upgrade to pro.
Keith
Keith
geposted Thu 17 Feb 11 @ 6:57 am
Please also ensure that you have the latest Hercules drivers and firmware installed, otherwise the consoles may not work with the latest versions.
A link to download this can be found on the following page:
https://virtualdj.com/wiki/Common_Device_Drivers.html
All Hercules controllers are supported in the latest VirtualDJ Pro https://virtualdj.com/buy/ and as above, they can be tried for 10 minutes at a time in Home FREE: https://virtualdj.com/download/free.html
geposted Thu 17 Feb 11 @ 8:17 am
so to use this controller on the 7 i will have to pay like $299?
geposted Thu 17 Feb 11 @ 12:55 pm
Yes, only the full VirtualDJ Pro supports MIDI controllers.
Home FREE supports mouse and keyboard only and is for non-commercial (Unpaid) use only (It cannot be legally used at DJ gigs where you are being paid.)
If the consoles came with VirtualDJ LE (Limited Edition), then you can use that instead, however it will be an older version of the software, can only be used with the hardware it came with (E.g: MP3 DJ Console Edition will only work with DJ Console MP3 connected) and is limited in features.
Assuming that it is not second hand or the discount has not already been used, you may be able to upgrade from VirtualDJ Console Edition to Pro at a discount by going to https://virtualdj.com/buy/ and enter the DJ Console software serial number in the box provided.
geposted Thu 17 Feb 11 @ 1:05 pm
