Forum: Old versions
Use this forum if you are still using an old version like VirtualDJ 7.
NOTE: VirtualDJ 7 is not maintained anymore.
Topic: "Error in the ASIO sound driver. Your soundcard is probably not connected, or the settings are incorrect..."
Just purchased Virtual DJ 7 Pro, have a Numark DJIO connected, and have it installed on a new Asus G73S running 64-bit Windows 7. I keep getting these errors: "Error in the ASIO sound driver: Not enough channels" then "Error in the ASIO sound driver. Your soundcard is probably not connected, or the settings are incorrect." Settings in VDJ are correct. Do I need to do something with the computer's sound card? Any help would be appreciated.
geposted Wed 27 Jul 11 @ 8:11 am
geposted Wed 27 Jul 11 @ 11:43 am
Actually this problem turned out to be very simple. I had the DJIO plugged into a USB 3.0 port. I plugged it into a USB 2.0 port and it worked right away. Odd that an error did not appear during the installation.
geposted Thu 28 Jul 11 @ 8:02 am
I'm having this same problem i purchased the numark mixtrack but i have the traktor audio 2 the traktor works with vdj but the mixtrack isn't connecting someone anyone have advice
geposted Thu 02 Aug 12 @ 10:32 pm
The reason you can't select an ASIO driver with the Mixtrack is that it doesn't have a sound card.
The Mixtrack Pro is the model with the sound card, and even that isn't an ASIO card.
geposted Fri 03 Aug 12 @ 8:34 am
slevyHome userMember since 2012
i am also gwtting this error message. ive just got the hercules dj control instonct and it came with the djuced programme which im not familiar with i have virtual dj pro 7 already and need help settong up the hercules mixer with vdj. thanks
geposted Sun 12 May 13 @ 6:51 am
Please register your Pro serial number to your account http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
Once you have done this, make sure that you have the latest drivers and firmware installed: http://www.virtualdj.com/wiki/Common%20Device%20Drivers.html
Then check your sound configuration - It should be similar to other Hercules products such as the 4-Mx: http://www.virtualdj.com/wiki/4-Mx.html
geposted Sun 12 May 13 @ 11:46 am
elect1PRO InfinityMember since 2011
I just install the Numark N4 with VDJ LE. "Error in the ASIO sound driver: Not enough channels" popped up. What do I do from this point.
geposted Wed 30 Oct 13 @ 11:16 am
Choose the correct sound settings.
geposted Wed 30 Oct 13 @ 11:21 am
Kings72Home userMember since 2016
Please help me.. Same problem Pop Up // Controller -->Hercules Dj Instinct
geposted Wed 06 Apr 16 @ 12:36 pm
tenho um controladora DDJ SB rodando 64 bits do Windows 7.estou recebendo esses erros: "Erro no driver de som ASIO: canais não é suficiente", em seguida, "Erro no driver de som ASIO. sua placa de som provavelmente não está ligada, ou as configurações estão incorretas. "Qualquer ajuda seria apreciada.
geposted Tue 07 Jun 16 @ 10:23 pm
