Forum: Old versions
For older version, like VirtualDJ 7.
NOTE: VirtualDJ 7 is not maintained anymore.
Topic: Download VirtualDJ Pro 7 to Windows 7 64bit
Can't Download VirtualDJ Pro 7 to Windows 7 64bit. Put disc in and it comes up with an error message. Error attempting to read from the source install database C;\Windows\Installer\2f2c80.msi Please help!!!
geposted Tue 16 Aug 11 @ 7:25 pm
It sounds like the installer is corrupt; try downloading it again from your download center: http://www.virtualdj.com/download/updates.html (it should be around 31MB)- if you're unable to download the installer straight onto the machine you're installing to, then try copying it via a usb drive or burning it at a slower speed if you're using a CD.
geposted Tue 16 Aug 11 @ 7:28 pm
BlulitePRO InfinityMember since 2009
i find its always better to use the instaler from the download centre and to have the system online during installation.
using the one from the download centre i had no problems at all instaling it into my x64 rig.
geposted Tue 16 Aug 11 @ 7:43 pm
I used Windowns 7 x64 since 2009 and never I had problems with the instalation... try to download again the Vdj setup...
geposted Tue 16 Aug 11 @ 8:35 pm
Try this, and let us know if it worked.
geposted Tue 16 Aug 11 @ 9:44 pm
Thanks Andrew87. I did what you said and it upgraded and worked for me. I was messing with it for about 2 hours after I logged on. I appreciate the advice!!
geposted Sat 20 Aug 11 @ 2:01 pm
I need to download Virtual DJ Pro 7. Where can I download it from?
geposted Fri 20 Oct 17 @ 10:44 pm
geposted Sat 21 Oct 17 @ 5:29 am
How to download the installer of virtual dj pro?
geposted Sun 31 Dec 17 @ 5:24 am
Click the button that says DOWNLOAD.
Of course it won't be the Pro version unless you have a Pro license.
geposted Sun 31 Dec 17 @ 8:40 am
Virtual dj 7 pro
geposted Sat 20 Jan 18 @ 4:18 pm
What about it?
geposted Sat 20 Jan 18 @ 4:26 pm
geposted Mon 22 Jan 18 @ 9:39 am
you are phucking robbers!!!!!
so now that i have a licence code for virtual dj 7 if i want to use it with my controller i have to pay to use virtual dj 8?
stop cheat people, now i'm gonna dowload traktor or a cracked versionof v. dj 8
my compliments!
geposted Wed 14 Mar 18 @ 7:08 pm
Great idea.
Get the cracked version, it's ace and won't infect your computer with malware in the slightest!
geposted Wed 14 Mar 18 @ 7:13 pm
