Hi,
I'm new to the DJ world and looking to purcahse either the Pro Basic or Pro Full software. I have 2 x Staton T-62 TT, Numark M101 mixer, Maya 44 sound card, and 2 x Serato time coded vinyls. I'm trying to find if the Pro Basic would work with this time coded setup. Are there any differences between the VDJ Pro Basic and Pro Full? Do you guys think it's user friendly for new DJ's? any info would be greatly appreciated!
thanks guys
thanks guys
geposted Tue 15 Nov 11 @ 9:46 am
Hi,
To use TC's you need the PRO Full version. The link below shows the differences.
geposted Tue 15 Nov 11 @ 10:39 am
Thanks! great info.
geposted Tue 15 Nov 11 @ 10:42 am
VDJ Pro FUll has some advantages over VDJ Pro Basic as far as the tc like mentioned above. VDJ is one of the most user friendly software you can find out there right now. Hope to see you as a Pro Full user and maybe even on virtual DJ Radio.
Happy Mixing
Charlie C
Happy Mixing
Charlie C
geposted Tue 15 Nov 11 @ 11:31 am
thanks charlie! how about the setup? I hear problems about not getting signal with the serato time coded vinyls. is that true in most cases?
geposted Tue 15 Nov 11 @ 12:30 pm
Yes you are right. It is because according to serato users forum the VDJ time coded vinyls is better than serato because serato vinyl uses noise coded data not binary coded.
geposted Tue 15 Nov 11 @ 1:35 pm
Well considering this is the VirutalDJ forum and since the Serato forum users don't know anything about our time code support engine ... that would be an incorrect statement.
The 'signal' quality really comes down to 2 factors - quality of sound card and quality if the needles being used.
Cheap card + Cheap needles = poor signal quality.
We actually suggest the use of the Rane CV-02 (SSL) Vinyl.
Needle suggestion are the SHURE M44-7 cartridges
Sound cards (there are a lot) but - the Hercules DeeJay Trim is a good starting point.
geposted Tue 15 Nov 11 @ 3:12 pm
So is there a difference between the 2 timecodes?? If so what is it??
Thanks for the info
Huey
Thanks for the info
Huey
geposted Tue 15 Nov 11 @ 4:54 pm
pretty sure it's the Hertz (frequency) the signal is made... kind of like ticks per rotation in terms of midi.
serato has 1000hz
traktor has 2000hz
dont know what numark has... probably 500hz
serato has 1000hz
traktor has 2000hz
geposted Tue 15 Nov 11 @ 11:41 pm
