djwove2005 wrote :
which one is best?
There is no best! It's simply personal choice. Use whatever method you're comfortable with.
I don't use the crossfader at all. I prefer to use the channel faders because IMO it allows me to balance the volumes of each track the way I want, rather than a preset amount governed by the position of a crossfader.
geposted Thu 24 Dec 15 @ 7:42 pm
Makes sense. Thanks!
geposted Fri 25 Dec 15 @ 6:24 pm
Crossfade works best when your bpms are close and you can sync it or match it by ear, the volume fade in and out is really good from going from lets say 150bmp to a 80 bpm song. It also depends if your doing a mashup you may use both in that case
geposted Sun 14 Feb 16 @ 7:39 pm
Do you have any idea if it's worth to pay $19 a month...I mean, I don't even know how to activate the subscription :)))) If anyone knows, pls explain me :)))) Thank You !
geposted Mon 26 Feb 18 @ 9:31 pm
I want to learn how to mix musics
geposted Thu 27 Sep 18 @ 4:18 pm
