Forum: Old versions
Topic: Forgot how to create Playlist in Virtual DJ 7
Using Virtual Folders but can't reorganize so going back to Playlists. ONG can't remember how to set them up--manual doesn't really go over that at least I can't find. Can somebody tell me?
Thanks,
Lady DJ
geposted Thu 09 Feb 12 @ 2:49 pm
bogartPRO InfinityMember since 2004
Choose your songs and drag them into the playlist section. (Far right)
Once you have finished your selection,right click the button for playlist management.
This will be in the playlist column under "title".
Then click save. A screen will pop up, now just name your playlist and save it.
geposted Fri 10 Feb 12 @ 8:57 am
using virtual dj 7.0.5 with the ergo LE version cant find a way to make a playlist so i can at least mingle go to the restroom , DRINK . ;) it was a feature on home edition PLEASE HELP thanks
geposted Wed 29 Feb 12 @ 12:24 pm
C4Custom
geposted Wed 29 Feb 12 @ 12:39 pm
geposted Thu 01 Mar 12 @ 8:15 am
YeyaRodPRO InfinityMember since 2012
I saved my playlist and the named the folder but now I can't find the playlist that I made.
I need help, Please!
geposted Sat 31 Mar 12 @ 12:57 pm
pweldonPRO InfinityMember since 2009
After you've created a playlist, you need to look at the folder tree on the left under the Playlist folder. You'll need to either recourse the folder structure or get out then get back in for VDJ to see the folder.
geposted Tue 03 Apr 12 @ 3:37 pm
If you already have the playlist set up, I cant find an easy way to edit the playlist. I have a list of about 30 songs to make a mix but wanted to go into the playlist to edit and add or take away songs. How is this done, not finding a how to on this, thanks.
geposted Sat 21 Apr 12 @ 11:36 am
Suddenly during a gig I suddenly couldnt open the folders to access my playlists, running the DDJ Ergo and the LE edition it came with, this seems to have affected the Home edition I have installed as well. this happened midset,no canges to any settings etc. Also during the gig the system froze, the cureent song played out but there was no response from the contriller or PC,talk about stress!!! HELP
geposted Sun 22 Apr 12 @ 4:50 am
VirtualDJ LE doesn't support using playlists except during the 20 day trial, so maybe this expired? See: http://www.virtualdj.com/products/comparison.html
For playlists and much, much more, you will need to upgrade to the full VirtualDJ Professional at a discount: http://www.virtualdj.com/buy/index.html
Also, check your computer for any performance issues: http://www.virtualdj.com/wiki/Performance%20Issues.html
And make sure that you have the latest drivers and firmware installed for the DDJ-ERGO - Please see: http://www.virtualdj.com/wiki/DDJ-ERGO.html
geposted Sun 22 Apr 12 @ 6:08 pm
I have the VDJ Pro 7.0.5 but are not able to create a playlist. I can't activate the Playlist-folder in any way, neither right-clicking, unfolding it nor anything. Neither can I drag any songs to the playlist section in the right. So how do I create a playlist with this fully licenced professional edition?
geposted Sat 21 Jul 12 @ 3:15 am
Where are you dragging songs from?
What happens when you try?
geposted Sat 21 Jul 12 @ 4:20 am
wspphanPRO InfinityMember since 2013
I created a playlist.
saved it
closed the program to test it.
re-opened it.
and the song titles and authors were gone...
geposted Fri 22 Mar 13 @ 12:38 pm
geposted Fri 22 Mar 13 @ 12:42 pm
They are from my external hard drive.
geposted Fri 22 Mar 13 @ 12:48 pm
does that matter???
The purpose of using my external hard drive is to save space on my computers hard drive.
geposted Fri 22 Mar 13 @ 12:51 pm
Shouldn't make any difference if they are on an internal or external drive. If they were live streamed from NetSearch/ContentUnlimited without caching first then they will turn into numbers instead of displaying artist, title, etc. because these songs don't exist as files on your hard disk.
However, if you are having issues with actual files on your disk, then make sure that they are tagged and named correctly - Please see: http://www.virtualdj.com/wiki/I%20cannot%20see%20the%20artist%20name%20or%20song%20title%20in%20the%20VirtualDJ%20browser.html
geposted Fri 22 Mar 13 @ 1:14 pm
Ola como montar uma PLAYLIST no Virtual DJ LE 7?
geposted Sun 29 Sep 13 @ 6:25 pm
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
Playlists are not available in VirtualDJ Limited Editions. You will need to upgrade your software to Pro Full version at a discount .. http://www.virtualdj.com/products/oem.html
geposted Mon 30 Sep 13 @ 12:22 am
pchakHome userMember since 2014
After installing the product, and playing with my new Vestax, I'm pretty disappointed that the LE version does not include something as basic as playlists and autoplay. It would seem to be in the best interest for VDJ to include this basic functionality or at least offer some type of discount on Pro Basic to entice someone to promote VDJ. The $199 "special price" is not much of a value when I would never consider upgrading for feature bloat (not an insult to the software, the added functionality is just not needed). I can get Serato for the equivalent price (with coupon) of VDJ Pro Basic.
Considering LE generates the m3u files anyway, it's almost a little disingenuous that playlists/autoplay are not included since I would assume that the hardware manufacturer paid some type of royalty or promotional consideration for LE. I like the software a lot, but feel just a little aggravated at the slight.
my 2 cents. Thanks,
geposted Sat 03 May 14 @ 10:43 am
